Datasheet Intersil ISL32455E — Даташит
Производитель | Intersil |
Серия | ISL32455E |
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 1Mbps Half-Duplex RS-485/RS-422, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
![]() 45 предложений от 20 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL32455EIBZ-T Renesas | 97 ₽ | ||
ISL32455EIBZ Renesas | 606 ₽ | ||
ISL32455EIUZ | от 699 ₽ | ||
ISL32455EIUZ | по запросу |
ISL32455EIBZ | ISL32455EIBZ-T | ISL32455EIBZ-T7A | ISL32455EIUZ | ISL32455EIUZ-T | ISL32455EIUZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
Parameters / Models | ISL32455EIBZ | ISL32455EIBZ-T | ISL32455EIBZ-T7A | ISL32455EIUZ | ISL32455EIUZ-T | ISL32455EIUZ-T7A |
# of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
Common Mode Voltage Range | В±20 V | В±20 V | В±20 V | В±20 V | В±20 V | В±20 V |
Скорость передачи данных | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps |
Description | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 1Mbps Half-Duplex RS-485/RS-422, ?15kV ESD |
Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 |
Fault Voltage Level | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V |
Half/Full Duplex | Half | Half | Half | Half | Half | Half |
High ESD? | Yes | Yes | Yes | Yes | Yes | Yes |
Hot Plug | No | No | No | No | No | No |
ICC | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA | 2.1 mA |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA | 10 μA |
Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes |
Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes |
VCC (min) | 3.0 V | 3.0 V | 3.0 V | 3.0 V | 3.0 V | 3.0 V |
VL Pin | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL32450E ISL32452E ISL32453E ISL32457E ISL32458E ISL32459E
Серия: ISL32455E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
