Datasheet Intersil ISL31498E — Даташит
ПроизводительIntersil
СерияISL31498E
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
17 предложений от 16 поставщиков
ИС интерфейса RS-422/RS-485 8LD OVP -40+85 5V RS 1/2 DUP 10MBPS TRAN
727GS
ISL31498EIUZ
Renesas
от 19 ₽
ISL31498EIBZ-T
Intersil
122 ₽
ISL31498EIBZ
Renesas
TradeElectronics
ISL31498EIBZ-T
Intersil
ISL31498EIBZISL31498EIBZ-TISL31498EIBZ-T7AISL31498EIUZISL31498EIUZ-TISL31498EIUZ-T7A
N123456
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsISL31498EIBZISL31498EIBZ-TISL31498EIBZ-T7AISL31498EIUZISL31498EIUZ-TISL31498EIUZ-T7A
# of Rx111111
# of Tx111111
Common Mode Voltage RangeВ±25 VВ±25 VВ±25 VВ±25 VВ±25 VВ±25 V
Скорость передачи данных15 Mbps15 Mbps15 Mbps15 Mbps15 Mbps15 Mbps
Description?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range
Devices Allowed on Bus128128128128128128
Fault Voltage LevelВ±60 VВ±60 VВ±60 VВ±60 VВ±60 VВ±60 V
Half/Full DuplexHalfHalfHalfHalfHalfHalf
High ESD?NoNoNoNoNoNo
Hot PlugYesYesYesYesYesYes
ICC2.3 mA2.3 mA2.3 mA2.3 mA2.3 mA2.3 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC50 μA50 μA50 μA50 μA50 μA50 μA
Slew Rate LimitedNoNoNoNoNoNo
Tx/Rx EnableYesYesYesYesYesYes
VCC (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL31490E ISL31491E ISL31492E ISL31495E ISL31496E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL31498E
