Datasheet Intersil ISL31492EIRTZ-T7A — Даташит
| Производитель | Intersil |
| Серия | ISL31492E |
| Модель | ISL31492EIRTZ-T7A |
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
Купить ISL31492EIRTZ-T7A на РадиоЛоцман.Цены — от 78 до 440 ₽12 предложений от 12 поставщиков Чип интерфейса, Single Transmitter/Receiver RS-422/RS-485 8Pin TDFN EP T/R | |||
| ISL31492EIRTZ-T7A Intersil | 78 ₽ | ||
| ISL31492EIRTZ-T7A Intersil | 91 ₽ | ||
| ISL31492EIRTZ-T7A Renesas | по запросу | ||
| ISL31492EIRTZ-T7A | по запросу | ||
| Корпус | 8 Ld DFN T+R |
| # of Rx | 1 |
| # of Tx | 1 |
| Common Mode Voltage Range | В±25 V |
| Скорость передачи данных | 0.25 Mbps |
| Description | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range |
| Devices Allowed on Bus | 128 |
| Fault Voltage Level | В±60 V |
| Half/Full Duplex | Half |
| High ESD? | No |
| Hot Plug | Yes |
| ICC | 2.3 mA |
| Peak Temp | 260°C |
| SHDN ICC | 50 μA |
| Slew Rate Limited | Yes |
| Tx/Rx Enable | Yes |
| VCC (min) | 4.5 V |
| VL Pin | No |
ISL31490E ISL31491E ISL31495E ISL31496E ISL31498E
Серия: ISL31492E (10)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
ISL31492EIRTZT7A, ISL31492EIRTZ T7A
