Datasheet Intersil ISL32459EIBZ-T — Даташит
| Производитель | Intersil |
| Серия | ISL32459E |
| Модель | ISL32459EIBZ-T |
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 20Mbps RS-485 With Cable Invert, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
|  Купить ISL32459EIBZ-T на РадиоЛоцман.Цены — от 116 до 1 336 ₽ 28 предложений от 13 поставщиков Чип интерфейса, ±60V Fault Protected, 3.3V to 5V, ±20V CMR, 20Mbps RS-485 With Cable Invert, ±15kV ESD | |||
| ISL32459EIBZ-T7A Intersil | 264 ₽ | ||
| ISL32459EIBZ-T Renesas | 309 ₽ | ||
| ISL32459EIBZ-T | 650 ₽ | ||
| ISL32459EIBZ-T7A Intersil | от 1 067 ₽ | ||
| Корпус | 8 Ld SOIC T+R |
| # of Rx | 1 |
| # of Tx | 1 |
| Common Mode Voltage Range | В±20 V |
| Скорость передачи данных | 20 Mbps |
| Description | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 20Mbps RS-485 With Cable Invert, ?15kV ESD |
| Devices Allowed on Bus | 128 |
| Fault Voltage Level | В±60 V |
| Half/Full Duplex | Half |
| High ESD? | Yes |
| Hot Plug | No |
| ICC | 2.1 mA |
| Peak Temp | 260°C |
| SHDN ICC | 10 μA |
| Slew Rate Limited | No |
| Tx/Rx Enable | Tx Only |
| VCC (min) | 3.0 V |
| VL Pin | No |
ISL32450E ISL32452E ISL32453E ISL32455E ISL32457E ISL32458E
Серия: ISL32459E (3)
- ISL32459EIBZ ISL32459EIBZ-T ISL32459EIBZ-T7A
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
ISL32459EIBZT, ISL32459EIBZ T
