Datasheet Intersil ISL32433EIUZ — Даташит
Производитель | Intersil |
Серия | ISL32433E |
Модель | ISL32433EIUZ |
В±40V Fault Protected, 3.3V to 5V, В±15V CMR, 1Mbps Full-Duplex RS-485/RS-422, В±15kV ESD
ISL32430E, ISL32432E, ISL32433E, ISL32435E, ISL32437E Datasheet
PDF, 1.2 Мб, Версия: 2017-10-10
![]() 34 предложений от 17 поставщиков , ±40V Fault Protected, 3.3V to 5V, ±15V Common Mode Range, RS-485/RS-422 Transceivers With Cable Invert and ±15kV ESD | |||
ISL32433EIUZ-T7A Intersil | 154 ₽ | ||
ISL32433EIUZ Intersil | от 219 ₽ | ||
ISL32433EIUZ Renesas | от 646 ₽ | ||
ISL32433EIUZ Renesas | от 651 ₽ |
Корпус | 10 Ld MSOP |
# of Rx | 1 |
# of Tx | 1 |
Common Mode Voltage Range | 15 V |
Скорость передачи данных | 1 Mbps |
Description | ?40V Fault Protected, 3.3V to 5V, ?15V CMR, 1Mbps Full-Duplex RS-485/RS-422, ?15kV ESD |
Devices Allowed on Bus | 128 |
Fault Voltage Level | В±40 V |
Half/Full Duplex | Full |
High ESD? | Yes |
Hot Plug | No |
ICC | 2.1 mA |
Peak Temp | 260°C |
SHDN ICC | 10 μA |
Slew Rate Limited | Yes |
Tx/Rx Enable | Yes |
VCC (min) | 3.3 V |
VL Pin | No |
ISL32430E ISL32432E ISL32435E ISL32437E
Серия: ISL32433E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
