Datasheet Intersil ISL32492E — Даташит
Производитель | Intersil |
Серия | ISL32492E |
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V CMR and ESD Protection
ISL32490E, ISL32492E, ISL32493E, ISL32495E, ISL32496E, ISL32498E Datasheet
PDF, 1.3 Мб, Версия: 2017-11-13
![]() 41 предложений от 22 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
ISL32492EIUZ-T Intersil | 128 ₽ | ||
ISL32492EIBZ-T Intersil | 155 ₽ | ||
ISL32492E Intersil | по запросу | ||
ISL32492EIBZ Renesas | по запросу |
ISL32492EIBZ | ISL32492EIBZ-T | ISL32492EIBZ-T7A | ISL32492EIUZ | ISL32492EIUZ-T | ISL32492EIUZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
Parameters / Models | ISL32492EIBZ | ISL32492EIBZ-T | ISL32492EIBZ-T7A | ISL32492EIUZ | ISL32492EIUZ-T | ISL32492EIUZ-T7A |
# of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
Common Mode Voltage Range | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V |
Скорость передачи данных | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps |
Description | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V CMR and ESD Protection |
Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 |
Fault Voltage Level | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V |
Half/Full Duplex | Half | Half | Half | Half | Half | Half |
High ESD? | Yes | Yes | Yes | Yes | Yes | Yes |
Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes |
ICC | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA |
Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes |
Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Pin | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL32490E ISL32493E ISL32495E ISL32496E ISL32498E
Серия: ISL32492E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
