Datasheet Intersil ISL31490E — Даташит
Производитель | Intersil |
Серия | ISL31490E |
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
![]() 18 предложений от 17 поставщиков Чип интерфейса, Single Transmitter/Receiver RS-422/RS-485 14Pin SOIC T/R | |||
ISL31490EIBZ Renesas | от 27 ₽ | ||
ISL31490EIBZ Renesas | 192 ₽ | ||
ISL31490EIBZ | по запросу | ||
ISL31490EIBZ-T Intersil | по запросу |
ISL31490EIBZ | ISL31490EIBZ-T | ISL31490EIBZ-T7A | ISL31490EIRTZ | ISL31490EIRTZ-T | ISL31490EIRTZ-T7A | ISL31490EIUZ | ISL31490EIUZ-T | ISL31490EIUZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
Корпус | 14 Ld SOIC | 14 Ld SOIC T+R | 14 Ld SOIC T+R | 10 Ld DFN | 10 Ld DFN T+R | 10 Ld DFN T+R | 10 Ld MSOP | 10 Ld MSOP T+R | 10 Ld MSOP T+R |
Parameters / Models | ISL31490EIBZ | ISL31490EIBZ-T | ISL31490EIBZ-T7A | ISL31490EIRTZ | ISL31490EIRTZ-T | ISL31490EIRTZ-T7A | ISL31490EIUZ | ISL31490EIUZ-T | ISL31490EIUZ-T7A |
# of Rx | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
# of Tx | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Common Mode Voltage Range | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V |
Скорость передачи данных | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps | 0.25 Mbps |
Description | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range |
Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 |
Fault Voltage Level | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V |
Half/Full Duplex | Full | Full | Full | Full | Full | Full | Full | Full | Full |
High ESD? | No | No | No | No | No | No | No | No | No |
Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
ICC | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
SHDN ICC | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA |
Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VL Pin | No | No | No | No | No | No | No | No | No |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL31491E ISL31492E ISL31495E ISL31496E ISL31498E
Серия: ISL31490E (9)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
