Datasheet Intersil ISL32452E — Даташит
ПроизводительIntersil
СерияISL32452E
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 250kbps Half-duplex RS-485/RS-422, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
43 предложений от 19 поставщиков
ISL32452EIBZ
Renesas
101 ₽
ISL32452EIUZ-T
Renesas
247 ₽
ISL32452EIUZ-T
410 ₽
ISL32452EIBZ
Renesas
от 536 ₽
ISL32452EIBZISL32452EIBZ-TISL32452EIBZ-T7AISL32452EIUZISL32452EIUZ-TISL32452EIUZ-T7A
N123456
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsISL32452EIBZISL32452EIBZ-TISL32452EIBZ-T7AISL32452EIUZISL32452EIUZ-TISL32452EIUZ-T7A
# of Rx111111
# of Tx111111
Common Mode Voltage RangeВ±20 VВ±20 VВ±20 VВ±20 VВ±20 VВ±20 V
Скорость передачи данных.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps
Description?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD
Devices Allowed on Bus128128128128128128
Fault Voltage LevelВ±60 VВ±60 VВ±60 VВ±60 VВ±60 VВ±60 V
Half/Full DuplexHalfHalfHalfHalfHalfHalf
High ESD?YesYesYesYesYesYes
Hot PlugNoNoNoNoNoNo
ICC2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC10 μA10 μA10 μA10 μA10 μA10 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (min)3.0 V3.0 V3.0 V3.0 V3.0 V3.0 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL32450E ISL32453E ISL32455E ISL32457E ISL32458E ISL32459E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL32452E
