Datasheet Intersil ISL32485E — Даташит
ПроизводительIntersil
СерияISL32485E
Fault Protected, Extended CMR, RS-485/RS-422 Transceivers with Cable Invert and В±16.5kV ESD
ISL32483E, ISL32485E Datasheet
PDF, 1.0 Мб, Версия: 2017-11-13
Чип интерфейса, ISL32485 Series 5.5V 1M/bps (-40+85C) RS-485/RS-422 Transceiver - SOIC-14
ISL32485EIBZ-T
Intersil
132 ₽
ISL32485EIBZ
Renesas
от 675 ₽
Microfind
ISL32485EIBZ
Renesas
830 ₽
727GS
ISL32485EIBZ
Intersil
ISL32485EIBZISL32485EIBZ-TISL32485EIBZ-T7A
N123
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsISL32485EIBZISL32485EIBZ-TISL32485EIBZ-T7A
# of Rx111
# of Tx111
Common Mode Voltage RangeВ±25 VВ±25 VВ±25 V
Скорость передачи данных1 Mbps1 Mbps1 Mbps
DescriptionFault Protected, Extended CMR, RS-485/RS-422 Transceivers with Cable Invert and ?16.5kV ESDFault Protected, Extended CMR, RS-485/RS-422 Transceivers with Cable Invert and ?16.5kV ESDFault Protected, Extended CMR, RS-485/RS-422 Transceivers with Cable Invert and ?16.5kV ESD
Devices Allowed on Bus128128128
Fault Voltage LevelВ±60 VВ±60 VВ±60 V
Half/Full DuplexHalfHalfHalf
High ESD?YesYesYes
Hot PlugYesYesYes
ICC2.3 mA2.3 mA2.3 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C
Qualification LevelStandardStandardStandard
SHDN ICCN/A μAN/A μAN/A μA
Slew Rate LimitedYesYesYes
Tx/Rx EnableTx OnlyTx OnlyTx Only
VCC (min)4.5 V4.5 V4.5 V
VL PinNoNoNo
ISL32483E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL32485E
