Datasheet Intersil ISL32432E — Даташит
ПроизводительIntersil
СерияISL32432E
В±40V Fault Protected, 3.3V to 5V, В±15V CMR, 250kbps Half-duplex RS-485/RS-422, В±15kV ESD
ISL32430E, ISL32432E, ISL32433E, ISL32435E, ISL32437E Datasheet
PDF, 1.2 Мб, Версия: 2017-10-10
44 предложений от 20 поставщиков
, ±40V Fault Protected, 3.3V to 5V, ±15V Common Mode Range, RS-485/RS-422 Transceivers With Cable Invert and ±15kV ESD
ISL32432EIBZ-T
128 ₽
ISL32432EIBZ-T
Intersil
129 ₽
ISL32432EIUZ
Renesas
от 465 ₽
ISL32432EIBZ-T
Intersil
ISL32432EIBZISL32432EIBZ-TISL32432EIBZ-T7AISL32432EIUZISL32432EIUZ-TISL32432EIUZ-T7A
N123456
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsISL32432EIBZISL32432EIBZ-TISL32432EIBZ-T7AISL32432EIUZISL32432EIUZ-TISL32432EIUZ-T7A
# of Rx111111
# of Tx111111
Common Mode Voltage RangeВ±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 V
Скорость передачи данных.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps
Description?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD?40V Fault Protected, 3.3V to 5V, ?15V CMR, 250kbps Half-duplex RS-485/RS-422, ?15kV ESD
Devices Allowed on Bus128128128128128128
Fault Voltage LevelВ±40 VВ±40 VВ±40 VВ±40 VВ±40 VВ±40 V
Half/Full DuplexHalfHalfHalfHalfHalfHalf
High ESD?YesYesYesYesYesYes
Hot PlugNoNoNoNoNoNo
ICC2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC10 μA10 μA10 μA10 μA10 μA10 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (min)3.3 V3.3 V3.3 V3.3 V3.3 V3.3 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL32430E ISL32433E ISL32435E ISL32437E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL32432E
