Datasheet Intersil ISL31495EIUZ-T — Даташит
Производитель | Intersil |
Серия | ISL31495E |
Модель | ISL31495EIUZ-T |
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
![]() 14 предложений от 13 поставщиков , PB-FREE 8LD MSOP OVP,-40+85, 5V, RS-485 1/2 DUPL 1MBPS Trans HT SUSA CODE:8542390000 | |||
ISL31495EIUZ-T Renesas | 67 ₽ | ||
ISL31495EIUZ-T Intersil | 98 ₽ | ||
ISL31495EIUZ-T Renesas | 192 ₽ | ||
ISL31495EIUZ-T7A Intersil | по запросу |
Корпус | 8 Ld MSOP T+R |
# of Rx | 1 |
# of Tx | 1 |
Common Mode Voltage Range | В±25 V |
Скорость передачи данных | 1 Mbps |
Description | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range |
Devices Allowed on Bus | 128 |
Fault Voltage Level | В±60 V |
Half/Full Duplex | Half |
High ESD? | No |
Hot Plug | Yes |
ICC | 2.3 mA |
Peak Temp | 260°C |
SHDN ICC | 50 μA |
Slew Rate Limited | Yes |
Tx/Rx Enable | Yes |
VCC (min) | 4.5 V |
VL Pin | No |
ISL31490E ISL31491E ISL31492E ISL31496E ISL31498E
Серия: ISL31495E (6)
- ISL31495EIBZ ISL31495EIBZ-T ISL31495EIBZ-T7A ISL31495EIUZ ISL31495EIUZ-T ISL31495EIUZ-T7A
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
ISL31495EIUZT, ISL31495EIUZ T
