Datasheet Intersil ISL31495E — Даташит
| Производитель | Intersil |
| Серия | ISL31495E |
В±60V Fault Protected, 5V, RS-485/RS-422 Transceivers with В±25V Common Mode Range
ISL31490E, ISL31491E, ISL31492E, ISL31493E, ISL31495E, ISL31496E, ISL31498E Datasheet
PDF, 1.5 Мб, Версия: 2017-11-13
Купить ISL31495E на РадиоЛоцман.Цены — от 54 до 387 ₽32 предложений от 17 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
| ISL31495EIUZ-T Renesas | 63 ₽ | ||
| ISL31495EIBZ Renesas | 145 ₽ | ||
| ISL31495EIBZ | 219 ₽ | ||
| ISL31495EIUZ Intersil | по запросу | ||
| ISL31495EIBZ | ISL31495EIBZ-T | ISL31495EIBZ-T7A | ISL31495EIUZ | ISL31495EIUZ-T | ISL31495EIUZ-T7A | |
| N | 1 | 2 | 3 | 4 | 5 | 6 |
| Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld MSOP | 8 Ld MSOP T+R | 8 Ld MSOP T+R |
| Parameters / Models | ISL31495EIBZ | ISL31495EIBZ-T | ISL31495EIBZ-T7A | ISL31495EIUZ | ISL31495EIUZ-T | ISL31495EIUZ-T7A |
| # of Rx | 1 | 1 | 1 | 1 | 1 | 1 |
| # of Tx | 1 | 1 | 1 | 1 | 1 | 1 |
| Common Mode Voltage Range | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V | В±25 V |
| Скорость передачи данных | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps | 1 Mbps |
| Description | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range | ?60V Fault Protected, 5V, RS-485/RS-422 Transceivers with ?25V Common Mode Range |
| Devices Allowed on Bus | 128 | 128 | 128 | 128 | 128 | 128 |
| Fault Voltage Level | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V | В±60 V |
| Half/Full Duplex | Half | Half | Half | Half | Half | Half |
| High ESD? | No | No | No | No | No | No |
| Hot Plug | Yes | Yes | Yes | Yes | Yes | Yes |
| ICC | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA | 2.3 mA |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 260°C | 260°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard |
| SHDN ICC | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA | 50 μA |
| Slew Rate Limited | Yes | Yes | Yes | Yes | Yes | Yes |
| Tx/Rx Enable | Yes | Yes | Yes | Yes | Yes | Yes |
| VCC (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
| VL Pin | No | No | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
ISL31490E ISL31491E ISL31492E ISL31496E ISL31498E
Серия: ISL31495E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
