Datasheet Intersil ISL32450EIUZ — Даташит
| Производитель | Intersil |
| Серия | ISL32450E |
| Модель | ISL32450EIUZ |
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 250kbps Full-duplex RS-485/RS-422, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
|  Купить ISL32450EIUZ на РадиоЛоцман.Цены — от 93 до 1 215 ₽ 27 предложений от 15 поставщиков , ±60V Fault Protected, 3.3V to 5V, ±20V Common-Mode Range, RS-485/RS-422 Transceivers with Cable Invert and ±15kV ESD | |||
| ISL32450EIUZ Renesas | 93 ₽ | ||
| ISL32450EIUZ-T7A Renesas | 687 ₽ | ||
| ISL32450EIUZ-T7A Renesas | от 953 ₽ | ||
| ISL32450EIUZ-T7A Intersil | от 1 039 ₽ | ||
| Корпус | 10 Ld MSOP |
| # of Rx | 1 |
| # of Tx | 1 |
| Common Mode Voltage Range | В±20 V |
| Скорость передачи данных | .25 Mbps |
| Description | ?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD |
| Devices Allowed on Bus | 128 |
| Fault Voltage Level | В±60 V |
| Half/Full Duplex | Full |
| High ESD? | Yes |
| Hot Plug | No |
| ICC | 2.1 mA |
| Peak Temp | 260°C |
| SHDN ICC | 10 μA |
| Slew Rate Limited | Yes |
| Tx/Rx Enable | Yes |
| VCC (min) | 3.0 V |
| VL Pin | No |
ISL32452E ISL32453E ISL32455E ISL32457E ISL32458E ISL32459E
Серия: ISL32450E (6)
- Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
