Datasheet Intersil ISL32450E — Даташит
ПроизводительIntersil
СерияISL32450E
В±60V Fault Protected, 3.3V to 5V, В±20V CMR, 250kbps Full-duplex RS-485/RS-422, В±15kV ESD
ISL32450E, ISL32452E, ISL32453E, ISL32455E, ISL32457E, ISL32458E, ISL32459E Datasheet
PDF, 1.6 Мб, Версия: 2017-08-31
16 предложений от 15 поставщиков
, ±60V Fault Protected, 3.3V to 5V, ±20V Common-Mode Range, RS-485/RS-422 Transceivers with Cable Invert and ±15kV ESD
ISL32450EIUZ-T
Intersil
180 ₽
ISL32450EIBZ-T
Renesas
283 ₽
ISL32450EIUZ
Renesas
МосЧип
ISL32450EIUZ
Intersil
ISL32450EIBZISL32450EIBZ-TISL32450EIBZ-T7AISL32450EIUZISL32450EIUZ-TISL32450EIUZ-T7A
N123456
Корпус14 Ld SOIC14 Ld SOIC T+R14 Ld SOIC T+R10 Ld MSOP10 Ld MSOP T+R10 Ld MSOP T+R
Parameters / ModelsISL32450EIBZISL32450EIBZ-TISL32450EIBZ-T7AISL32450EIUZISL32450EIUZ-TISL32450EIUZ-T7A
# of Rx111111
# of Tx111111
Common Mode Voltage RangeВ±20 VВ±20 VВ±20 VВ±20 VВ±20 VВ±20 V
Скорость передачи данных.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps.25 Mbps
Description?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD?60V Fault Protected, 3.3V to 5V, ?20V CMR, 250kbps Full-duplex RS-485/RS-422, ?15kV ESD
Devices Allowed on Bus128128128128128128
Fault Voltage LevelВ±60 VВ±60 VВ±60 VВ±60 VВ±60 VВ±60 V
Half/Full DuplexFullFullFullFullFullFull
High ESD?YesYesYesYesYesYes
Hot PlugNoNoNoNoNoNo
ICC2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA2.1 mA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandard
SHDN ICC10 μA10 μA10 μA10 μA10 μA10 μA
Slew Rate LimitedYesYesYesYesYesYes
Tx/Rx EnableYesYesYesYesYesYes
VCC (min)3.0 V3.0 V3.0 V3.0 V3.0 V3.0 V
VL PinNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
ISL32452E ISL32453E ISL32455E ISL32457E ISL32458E ISL32459E
  • Interface ICs > RS-485, RS-422 & RS-232 > RS-485/RS-422 Fault Protected
На английском языке: Datasheet Intersil ISL32450E
