Datasheet Intersil ISL29112 — Даташит
Производитель | Intersil |
Серия | ISL29112 |
Низкая мощность, оптимизированный <100 люкс, датчик внешней освещенности с аналоговым выходом
![]() 9 предложений от 9 поставщиков Evaluation Board, ISL29112 Ambient Light Sensor, Low Power, Analog Output, 0.01 lux To 100 lux | |||
ISL29112IROZ-T7 Intersil | 81 ₽ | ||
ISL29112IROZ-EVALZ Intersil | 4 976 ₽ | ||
ISL29112IROZ-T7 Renesas | по запросу | ||
ISL29112IROZ-T7 | ISL29112IROZ-T7A | |
N | 1 | 2 |
Корпус | 6 Ld ODFN T+R | 6 Ld ODFN T+R |
Parameters / Models | ISL29112IROZ-T7 | ISL29112IROZ-T7A |
Dark Voltage @ EV=0Lux | .95 mV | .95 mV |
Delay Time, Falling Edge (Ојs) | 250 @ 100Lux | 250 @ 100Lux |
Delay Time, Rising Edge (Ојs) | 350 @ 100Lux | 350 @ 100Lux |
Description | Low Power, 100 Lux Optimized, Analog Output Ambient Light Sensor | Low Power, 100 Lux Optimized, Analog Output Ambient Light Sensor |
Enable Pin? | Yes | Yes |
Fall Time | 155 μs | 155 μs |
Lux Range (max) | 100 lux | 100 lux |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 |
Output Voltage @ EV=100Lux | 1.85 V | 1.85 V |
Package Dimensions (mm) | 2x2.1x0.7 | 2x2.1x0.7 |
Pb Free? | Yes | Yes |
Peak Spectral Sensitivity | 550 nm | 550 nm |
Peak Temp | 260°C | 260°C |
Qualification Level | Standard | Standard |
Rise Time | 95 μs | 95 μs |
Supply Current @ EV =100Lux | 23 μA | 23 μA |
VS (max) | 3.0 V | 3.0 V |
VS (min) | 1.8 V | 1.8 V |
Серия: ISL29112 (2)
- Optoelectronics > Ambient Light Sensors > Light to Analog Sensors (Voltage)
