Datasheet Intersil HI-547 — Даташит
| Производитель | Intersil |
| Серия | HI-547 |
Дифференциальные 8-канальные аналоговые КМОП-мультиплексоры с активной защитой от перенапряжения
| HI1-0547-5 | HI3-0547-5 | HI3-0547-5Z | HI4P0547-5 | HI4P0547-5Z | HI9P0547-9 | HI9P0547-9Z | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
| Корпус | 28 Ld CERDIP | 28 Ld PDIP | 28 Ld PDIP | 28 Ld PLCC | 28 Ld PLCC | 28 Ld SOIC | 28 Ld SOIC |
| Parameters / Models | HI1-0547-5 | HI3-0547-5 | HI3-0547-5Z | HI4P0547-5 | HI4P0547-5Z | HI9P0547-9 | HI9P0547-9Z |
| Количество каналов | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
| Chg Inj | 4 pC | 4 pC | 4 pC | 4 pC | 4 pC | 4 pC | 4 pC |
| Configuration | 2 x 8:1 | 2 x 8:1 | 2 x 8:1 | 2 x 8:1 | 2 x 8:1 | 2 x 8:1 | 2 x 8:1 |
| Description | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection | Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection |
| Drain Cap | 30 pF | 30 pF | 30 pF | 30 pF | 30 pF | 30 pF | 30 pF |
| IS | 500 μA | 500 μA | 500 μA | 500 μA | 500 μA | 500 μA | 500 μA |
| Leakage | 0.1 nA | 0.1 nA | 0.1 nA | 0.1 nA | 0.1 nA | 0.1 nA | 0.1 nA |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 220°C | 245°C | 240°C | 260°C | |||
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Source Cap | 10 pF | 10 pF | 10 pF | 10 pF | 10 pF | 10 pF | 10 pF |
| Switch or MUX | MUX | MUX | MUX | MUX | MUX | MUX | MUX |
| TOFF | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns |
| TON | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns | 300 ns |
| Type of Switch | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| VCC (Dual) (max) | В±18 V | В±18 V | В±18 V | В±18 V | В±18 V | В±18 V | В±18 V |
| VCC (Dual) (min) | В±5 V | В±5 V | В±5 V | В±5 V | В±5 V | В±5 V | В±5 V |
| VCC (Single) (max) | 18 V | 18 V | 18 V | 18 V | 18 V | 18 V | 18 V |
| rDS(ON) | 1200 Ω | 1200 Ω | 1200 О© | 1200 Ω | 1200 О© | 1200 Ω | 1200 О© |
| RoHS | Совместим | Совместим | Совместим |
Серия: HI-547 (7)
- Switches, MUX & Crosspoints > High Voltage > Switches/MUXs/Crosspoints
