Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet Intersil ISL84052 — Даташит
ПроизводительIntersil
СерияISL84052
Низкое напряжение, одинарное и двойное питание, двойной мультиплексор 4-в-1
ISL84051, ISL84052, ISL84053 Datasheet
PDF, 936 Кб, Версия: 2017-10-23
ISL84052IAISL84052IA-TISL84052IAZISL84052IAZ-TISL84052IBISL84052IB-TISL84052IBZISL84052IBZ-TISL84052IBZ-T7AISL84052IVZISL84052IVZ-TISL84052IVZ-T7A
N123456789101112
Корпус16 Ld QSOP16 Ld QSOP T+R16 Ld QSOP16 Ld QSOP T+R16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC16 Ld SOIC T+R16 Ld SOIC T+R16 Ld TSSOP16 Ld TSSOP T+R16 Ld TSSOP T+R
Parameters / ModelsISL84052IAISL84052IA-TISL84052IAZISL84052IAZ-TISL84052IBISL84052IB-TISL84052IBZISL84052IBZ-TISL84052IBZ-T7AISL84052IVZISL84052IVZ-TISL84052IVZ-T7A
Количество каналов888888888888
Chg Inj2 pC2 pC2 pC2 pC2 pC2 pC2 pC2 pC2 pC2 pC2 pC2 pC
Configuration2 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:12 x 4:1
DescriptionLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 MultiplexerLow Voltage, Single and Dual Supply, Dual 4-to-1 Multiplexer
Drain Cap18 pF18 pF18 pF18 pF18 pF18 pF18 pF18 pF18 pF18 pF18 pF18 pF
IS0.1 μA0.1 µA0.1 μA0.1 μA0.1 μA0.1 µA0.1 μA0.1 μA0.1 μA0.1 μA0.1 μA0.1 μA
Leakage2 pA2 pA2 pA2 pA2 pA2 pA2 pA2 pA2 pA2 pA2 pA2 pA
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Peak Temp240°C240°C260°C260°C240°C240°C260°C260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Source Cap3 pF3 pF3 pF3 pF3 pF3 pF3 pF3 pF3 pF3 pF3 pF3 pF
Switch or MUXMUXMUXMUXMUXMUXMUXMUXMUXMUXMUXMUXMUX
TOFF40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns
TON50 ns50 ns50 ns50 ns50 ns50 ns50 ns50 ns50 ns50 ns50 ns50 ns
Type of SwitchN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
VCC (Dual) (max)В±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 VВ±6 V
VCC (Dual) (min)В±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 VВ±2 V
VCC (Single) (max)12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V12 V
VCC (Single) (min)2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V
rDS(ON)60 О©60 Ω60 О©60 О©60 О©60 Ω60 О©60 О©60 О©60 О©60 О©60 О©
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
ISL84051 ISL84053
  • Switches, MUX & Crosspoints > Low Voltage > Switches/MUXs/Crosspoints
На английском языке: Datasheet Intersil ISL84052
Политика конфиденциальности
