Datasheet Intersil ISL84051 — Даташит
| Производитель | Intersil |
| Серия | ISL84051 |
Низкое напряжение, одинарное и двойное питание, мультиплексор 8-к-1
| ISL84051IA | ISL84051IA-T | ISL84051IAZ | ISL84051IAZ-T | ISL84051IB | ISL84051IB-T | ISL84051IBZ | ISL84051IBZ-T | ISL84051IVZ | ISL84051IVZ-T | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
| Корпус | 16 Ld QSOP | 16 Ld QSOP T+R | 16 Ld QSOP | 16 Ld QSOP T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld SOIC | 16 Ld SOIC T+R | 16 Ld TSSOP | 16 Ld TSSOP T+R |
| Parameters / Models | ISL84051IA | ISL84051IA-T | ISL84051IAZ | ISL84051IAZ-T | ISL84051IB | ISL84051IB-T | ISL84051IBZ | ISL84051IBZ-T | ISL84051IVZ | ISL84051IVZ-T |
| Количество каналов | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Chg Inj | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC | 2 pC |
| Configuration | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 | 1 x 8:1 |
| Description | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer | Low Voltage, Single and Dual Supply, 8-to-1 Multiplexer |
| Drain Cap | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF | 26 pF |
| IS | 0.1 µA | 0.1 µA | 0.1 μA | 0.1 μA | 0.1 µA | 0.1 µA | 0.1 μA | 0.1 μA | 0.1 μA | 0.1 μA |
| Leakage | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 240°C | 260°C | 260°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C |
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Source Cap | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF | 3 pF |
| Switch or MUX | MUX | MUX | MUX | MUX | MUX | MUX | MUX | MUX | MUX | MUX |
| TOFF | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns | 40 ns |
| TON | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns | 50 ns |
| Type of Switch | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A |
| VCC (Dual) (max) | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V | В±6 V |
| VCC (Dual) (min) | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V | В±2 V |
| VCC (Single) (max) | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V | 12 V |
| VCC (Single) (min) | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V | 2 V |
| rDS(ON) | 60 Ω | 60 Ω | 60 О© | 60 О© | 60 Ω | 60 Ω | 60 О© | 60 О© | 60 О© | 60 О© |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ISL84051 (10)
- Switches, MUX & Crosspoints > Low Voltage > Switches/MUXs/Crosspoints
