Datasheet Intersil HSP45102 — Даташит
ПроизводительIntersil
СерияHSP45102
12-битный NCO 28 SOIC, 40 МГц, COMM
HSP45102 Datasheet
PDF, 191 Кб, Версия: 2014-11-14
18 предложений от 18 поставщиков
Набор разработчика, Numerical Controlled Oscillator 28Pin SOIC W
727GS
HSP45102SC-40
Intersil
HSP45102R3406
ТаймЧипс
HSP45102-3S
Intersil
HSP45102SI-33
Harris
HSP45102PC-33HSP45102PC-40HSP45102SC-33HSP45102SC-3396HSP45102SC-33ZHSP45102SC-40HSP45102SC-40ZHSP45102SI-33HSP45102SI-3396HSP45102SI-33Z
N12345678910
Корпус28 Ld PDIP28 Ld PDIP28 Ld SOIC28 Ld SOIC T+R28 Ld SOIC28 Ld SOIC28 Ld SOIC28 Ld SOIC28 Ld SOIC T+R28 Ld SOIC
Parameters / ModelsHSP45102PC-33HSP45102PC-40HSP45102SC-33HSP45102SC-3396HSP45102SC-33ZHSP45102SC-40HSP45102SC-40ZHSP45102SI-33HSP45102SI-3396HSP45102SI-33Z
Description12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM12-Bit NCO 28 SOIC, 40MHz, COMM
Filter SubtypeNCONCONCONCONCONCONCONCONCONCO
FilteringNoneNoneNoneNoneNoneNoneNoneNoneNoneNone
Frequency Resolution (Hz)0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits0.009 @ 32-Bits
Input Data12 Bits12 Bits12 Bits12 Bits12 Bits12 Bits12 Bits12 Bits12 Bits12 Bits
Input Rate (MSPS)40404040404040404040
Modulation FormatsQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSKQPSK, FSK
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz12-Bits, Sine 40MHz
Peak Temp240°C240°C260°C240°C260°C240°C240°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
Spectral Purity (dBc)69696969696969696969
  • Timing & Digital ICs > DSP > DSP Synthesizers
На английском языке: Datasheet Intersil HSP45102
