Datasheet Intersil ICM7228 — Даташит
| Производитель | Intersil |
| Серия | ICM7228 |
8-разрядный, совместимый с микропроцессором драйвер декодера светодиодного дисплея
36 предложений от 28 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления дисплеем | |||
| ICM7228DIJI Harris | 58 ₽ | ||
| ICM7228AIPIZ | 261 ₽ | ||
| ICM7228CIPIZ Renesas | от 1 640 ₽ | ||
| ICM7228IJI Intersil | по запросу | ||
| ICM7228AIBI | ICM7228AIBIZ | ICM7228AIPI | ICM7228AIPIZ | ICM7228BIBI | ICM7228BIBIZ | ICM7228BIPI | ICM7228BIPIZ | ICM7228CIBI | ICM7228CIBIZ | ICM7228CIPI | ICM7228CIPIZ | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Корпус | 28 Ld SOIC | 28 Ld SOIC | 28 Ld PDIP | 28 Ld PDIP | 28 Ld SOIC | 28 Ld SOIC | 28 Ld PDIP | 28 Ld PDIP | 28 Ld SOIC | 28 Ld SOIC | 28 Ld PDIP | 28 Ld PDIP |
| Parameters / Models | ICM7228AIBI | ICM7228AIBIZ | ICM7228AIPI | ICM7228AIPIZ | ICM7228BIBI | ICM7228BIBIZ | ICM7228BIPI | ICM7228BIPIZ | ICM7228CIBI | ICM7228CIBIZ | ICM7228CIPI | ICM7228CIPIZ |
| # of Digits | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Alphanumeric? | No | No | No | No | No | No | No | No | No | No | No | No |
| Cycle Time | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns | 500 ns |
| Description | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver | 8-Digit, Microprocessor-Compatible, LED Display Decoder Driver |
| Display Type | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC | LED, CA or CC |
| Font | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX | CODE B, HEX |
| Interface Type | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. |
| Multiplexed? | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Peak Temp | 240°C | 260°C | 240°C | 260°C | 240°C | 260°C | ||||||
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Интерфейс | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. | BIT PAR.,DIGIT SER. |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: ICM7228 (12)
- Timing & Digital ICs > Microprocessors and Peripherals > Display Drivers
