Datasheet Intersil ISL12022MIBZ-T — Даташит
Производитель | Intersil |
Серия | ISL12022M |
Модель | ISL12022MIBZ-T |
Low Power RTC Module with Battery Backed SRAM, Integrated В±5ppm Temperature Sensor and Crystal
![]() 38 предложений от 18 поставщиков Микросхема часы реального времени, Real Time Clock Serial 128Byte Clock/Calendar/Alarm/Interrupt/Battery Backup 20Pin SOIC T/R | |||
ISL12022MIBZ-T7A Intersil | 66 ₽ | ||
ISL12022MIBZ-T Intersil | 119 ₽ | ||
ISL12022MIBZ-T Renesas | 613 ₽ | ||
ISL12022MIBZ-T Intersil | по запросу |
Корпус | 20 Ld SOIC T+R |
Точность | В±5 ppm |
Alarms | 1 |
Battery Backup | Yes |
Battery Seal | Yes |
CPU Supervisory Function POR | No |
CPU Supervisory Function Watchdog Timer | No |
Crystal Frequency Trimming | Yes |
Description | Low Power RTC Module with Battery Backed SRAM, Integrated ?5ppm Temperature Sensor and Crystal |
FOUT | IRQ_bar/FOUT |
Freq. Out Pin | Yes |
IBAT | 1000 nA |
IRQ Pin | Yes |
IRQ_Bar | IRQ_bar/FOUT |
Memory Type | RAM |
Oscillator Compensation (ppm) | -336 to +337 |
Other Functions | Battery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight Savings |
Peak Temp | 260°C |
RESET_bar | No |
Reset | No |
SRAM | 128 Bytes |
Selectable Frequency Output | 15 |
Tamper Detect | No |
Time Keeping Current | 3.5 μA |
Timer | No |
VBAT (max) | 5.5 V |
VBAT (min) | 1.8 V |
VCC (max) | 5.5 V |
VCC (min) | 2.7 V |
VTRIP for POR | 6 Select VTRIP Levels |
Интерфейс | I2C |
Серия: ISL12022M (2)
- ISL12022MIBZ ISL12022MIBZ-T
- Timing & Digital ICs > Real Time Clocks > Real Time Clocks
ISL12022MIBZT, ISL12022MIBZ T
