Datasheet Intersil ISL12022M — Даташит
ПроизводительIntersil
СерияISL12022M
Low Power RTC Module with Battery Backed SRAM, Integrated В±5ppm Temperature Sensor and Crystal
ISL12022M Datasheet
PDF, 1.3 Мб, Версия: 2017-11-22
7 предложений от 7 поставщиков
, Low Power RTC with Battery Backed SRAM, Integrated ±5ppm Temperature Compensation, and Auto Daylight Saving
ISL12022M-EVAL
Intersil
1 822 ₽
ISL12022M-EVAL
Intersil
1 822 ₽
ISL12022M-EVAL
МосЧип
ISL12022M_10
Intersil
ISL12022MIBZISL12022MIBZ-T
N12
Корпус20 Ld SOIC20 Ld SOIC T+R
Parameters / ModelsISL12022MIBZISL12022MIBZ-T
ТочностьВ±5 ppmВ±5 ppm
Alarms11
Battery BackupYesYes
Battery SealYesYes
CPU Supervisory Function PORNoNo
CPU Supervisory Function Watchdog TimerNoNo
Crystal Frequency TrimmingYesYes
DescriptionLow Power RTC Module with Battery Backed SRAM, Integrated ?5ppm Temperature Sensor and CrystalLow Power RTC Module with Battery Backed SRAM, Integrated ?5ppm Temperature Sensor and Crystal
FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYes
IBAT1000 nA1000 nA
IRQ PinYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeRAMRAM
Рабочий диапазон температурот -40 до 85от -40 до 85
Oscillator Compensation (ppm)-336 to +337-336 to +337
Other FunctionsBattery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight SavingsBattery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight Savings
Peak Temp260°C260°C
Qualification LevelStandardStandard
RESET_barNoNo
ResetNoNo
SRAM128 Bytes128 Bytes
Selectable Frequency Output1515
Tamper DetectNoNo
Time Keeping Current3.5 μA3.5 μA
TimerNoNo
VBAT (max)5.5 V5.5 V
VBAT (min)1.8 V1.8 V
VCC (max)5.5 V5.5 V
VCC (min)2.7 V2.7 V
VTRIP for POR6 Select VTRIP Levels6 Select VTRIP Levels
ИнтерфейсI2CI2C
RoHSСовместимСовместим
Серия: ISL12022M (2)
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL12022M
