Datasheet Intersil ISL12026 — Даташит
ПроизводительIntersil
СерияISL12026
Часы/календарь реального времени с шиной I 2 C и EEPROM
ISL12026, ISL12026A Datasheet
PDF, 1.0 Мб, Версия: 2017-11-20
48 предложений от 24 поставщиков
Микросхема часы реального времени, Pb-Free, Real Time Clock/Calendar with EEPROM in 8 LD TSSOP HT SUSA CODE:8542390000
ISL12026IBZ (ISL12026IBZ  )
Intersil
SUV System
ISL12026IVZ
LifeElectronics
ISL12026
Intersil
ISL12026IBZ-T
Intersil
ISL12026IBZISL12026IBZ-TISL12026IBZ-T7AISL12026IVZISL12026IVZ-T
N12345
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld TSSOP8 Ld TSSOP T+R
Parameters / ModelsISL12026IBZISL12026IBZ-TISL12026IBZ-T7AISL12026IVZISL12026IVZ-T
Alarms22222
Battery BackupYesYesYesYesYes
Battery SealYesYesYesYesYes
CPU Supervisory Function PORNoNoNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNoNoNo
Crystal Frequency TrimmingYesYesYesYesYes
DescriptionReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROMReal Time Clock/Calendar with I2C Bus? and EEPROM
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYesYesYes
IBAT850 nA850 nA850 nA850 nA850 nA
IRQ PinYesYesYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeEEPROMEEPROMEEPROMEEPROMEEPROM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-64 to +110-64 to +110-64 to +110-64 to +110-64 to +110
Peak Temp260°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandard
RESET_barNoNoNoNoNo
ResetNoNoNoNoNo
SRAM512x8-Bit EEPROM512x8-Bit EEPROM512x8-Bit EEPROM512x8-Bit EEPROM512x8-Bit EEPROM
Selectable Frequency Output33333
Tamper DetectNoNoNoNoNo
Time Keeping Current5 μA5 μA5 μA5 μA5 μA
TimerNoNoNoNoNo
VBAT (max)5.5 V5.5 V5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V
ИнтерфейсI2CI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместимСовместим
ISL12026A
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL12026
