Datasheet Intersil ISL12020M — Даташит
ПроизводительIntersil
СерияISL12020M
Real Time Clock with Embedded Crystal, В±5ppm Accuracy
ISL12020M Datasheet
PDF, 1.4 Мб, Версия: 2017-11-22
Часы реального времени LDAL TIME CLK & TEMP COMPENSATED CR
727GS
ISL12020M
Intel
7 625 ₽
ISL12020M
Intersil
ISL12020M
ISL12020MIRZISL12020MIRZ-TISL12020MIRZ-T7A
N123
Корпус20 Ld DFN20 Ld DFN T+R20 Ld DFN T+R
Parameters / ModelsISL12020MIRZISL12020MIRZ-TISL12020MIRZ-T7A
ТочностьВ±5 ppmВ±5 ppmВ±5 ppm
Alarms111
Battery BackupYesYesYes
Battery SealYesYesYes
CPU Supervisory Function PORNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNo
Crystal Frequency TrimmingYesYesYes
DescriptionReal Time Clock with Embedded Crystal, ?5ppm AccuracyReal Time Clock with Embedded Crystal, ?5ppm AccuracyReal Time Clock with Embedded Crystal, ?5ppm Accuracy
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYes
IBAT1000 nA1000 nA1000 nA
IRQ PinYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeRAMRAMRAM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-336 to +337-336 to +337-336 to +337
Other FunctionsBattery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight SavingsBattery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight SavingsBattery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight Savings
Peak Temp260°C260°C260°C
Qualification LevelStandardStandardStandard
RESET_barNoNoNo
ResetNoNoNo
SRAM128 Bytes128 Bytes128 Bytes
Selectable Frequency Output151515
Tamper DetectNoNoNo
Time Keeping Current3.5 μA3.5 μA3.5 μA
TimerNoNoNo
VBAT (max)5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V
VTRIP for POR6 Select VTRIP Levels6 Select VTRIP Levels6 Select VTRIP Levels
ИнтерфейсI2CI2CI2C
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL12020M
