Datasheet Intersil ISL1208 — Даташит
ПроизводительIntersil
СерияISL1208
I2CВ® Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAM
ISL1208 Datasheet
PDF, 1.0 Мб, Версия: 2017-11-02
19 предложений от 19 поставщиков
Интегральные микросхемы Тактовые микросхемы - Генераторы реального времени
ISL1208IB8
Intersil
81 ₽
Элитан
ISL1208IU8
Renesas
329 ₽
SUV System
ISL1208IB8
ISL1208IU8
Intersil
ISL1208IB8ISL1208IB8-TKISL1208IB8ZISL1208IB8Z-T7AISL1208IB8Z-TKISL1208IRT8ZISL1208IRT8Z-TKISL1208IU8ISL1208IU8-TKISL1208IU8ZISL1208IU8Z-T7AISL1208IU8Z-TK
N123456789101112
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld DFN8 Ld DFN T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP8 Ld MSOP T+R8 Ld MSOP T+R
Parameters / ModelsISL1208IB8ISL1208IB8-TKISL1208IB8ZISL1208IB8Z-T7AISL1208IB8Z-TKISL1208IRT8ZISL1208IRT8Z-TKISL1208IU8ISL1208IU8-TKISL1208IU8ZISL1208IU8Z-T7AISL1208IU8Z-TK
Alarms111111111111
Battery BackupYesYesYesYesYesYesYesYesYesYesYesYes
Battery SealYesYesYesYesYesYesYesYesYesYesYesYes
CPU Supervisory Function PORNoNoNoNoNoNoNoNoNoNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNoNoNoNoNoNoNoNoNoNo
Crystal Frequency TrimmingYesYesYesYesYesYesYesYesYesYesYesYes
DescriptionI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAMI2C? Real Time Clock/Calendar, Low Power RTC with Battery Backed SRAM
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYesYesYesYesYesYesYesYesYesYes
IBAT400 nA400 nA400 nA400 nA400 nA400 nA400 nA400 nA400 nA400 nA400 nA400 nA
IRQ PinYesYesYesYesYesYesYesYesYesYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeRAMRAMRAMRAMRAMRAMRAMRAMRAMRAMRAMRAM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140
Peak Temp240°C240°C260°C260°C260°C260°C260°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandardStandard
RESET_barNoNoNoNoNoNoNoNoNoNoNoNo
ResetNoNoNoNoNoNoNoNoNoNoNoNo
SRAM2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes
Selectable Frequency Output151515151515151515151515
Tamper DetectNoNoNoNoNoNoNoNoNoNoNoNo
Time Keeping Current1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA
VBAT (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V2.7 V
VTRIP for PORYesYesYesYesYesYesYesYesYesYesYesYes
ИнтерфейсI2CI2CI2CI2CI2CI2CI2CI2CI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL1208
