Datasheet Intersil ISL12022MIBZR5421 — Даташит
| Производитель | Intersil |
| Серия | ISL12022MR5421 |
| Модель | ISL12022MIBZR5421 |
Модуль RTC с низким энергопотреблением, SRAM с батарейным питанием, встроенной температурной компенсацией и автоматическим переходом на летнее время.
Купить ISL12022MIBZR5421 на РадиоЛоцман.Цены — от 81 до 519 ₽12 предложений от 12 поставщиков Микросхема часы реального времени, Real Time Clock Serial 128Byte Clock/Calendar/Alarm/Interrupt/Battery Backup 20Pin SOIC W Tube | |||
| ISL12022MIBZR5421 Intersil | 81 ₽ | ||
| ISL12022MIBZR5421 Intersil | 264 ₽ | ||
| ISL12022MIBZR5421 | 519 ₽ | ||
| ISL12022MIBZR5421 | по запросу | ||
| Корпус | 20 Ld SOIC |
| Точность | В±5 ppm |
| Alarms | 1 |
| Battery Backup | Yes |
| Battery Seal | Yes |
| CPU Supervisory Function POR | No |
| CPU Supervisory Function Watchdog Timer | No |
| Crystal Frequency Trimming | Yes |
| Description | Low Power RTC Module with Battery Backed SRAM, Integrated Temp Comp and Auto Daylight Saving |
| FOUT | IRQ_bar/FOUT |
| Freq. Out Pin | Yes |
| IBAT | 1000 nA |
| IRQ Pin | Yes |
| IRQ_Bar | IRQ_bar/FOUT |
| Memory Type | RAM |
| Oscillator Compensation (ppm) | -336 to +337 |
| Other Functions | Battery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight Savings |
| Peak Temp | 260°C |
| RESET_bar | No |
| Reset | No |
| SRAM | 128 Bytes |
| Selectable Frequency Output | 15 |
| Tamper Detect | No |
| Time Keeping Current | 3.5 μA |
| Timer | No |
| VBAT (max) | 5.5 V |
| VBAT (min) | 1.8 V |
| VCC (max) | 5.5 V |
| VCC (min) | 2.7 V |
| VTRIP for POR | 6 Select VTRIP Levels |
| Интерфейс | I2C |
Серия: ISL12022MR5421 (2)
- ISL12022MIBZ-TR5421 ISL12022MIBZR5421
- Timing & Digital ICs > Real Time Clocks > Real Time Clocks
