Datasheet Intersil ISL12022IBZ — Даташит
Производитель | Intersil |
Серия | ISL12022 |
Модель | ISL12022IBZ |
Low Power RTC with Battery-Backed SRAM and Embedded Temp Comp В±5ppm with Auto Day Light Saving
![]() 45 предложений от 19 поставщиков Микросхема часы реального времени, Real Time Clock Serial 128Byte Clock/Calendar/Alarm/Interrupt/Battery Backup 8Pin SOIC N T/R | |||
ISL12022IBZ-T Intersil | 230 ₽ | ||
ISL12022IBZ Intersil | от 1 307 ₽ | ||
ISL12022IBZ-T7A Intersil | по запросу | ||
ISL12022IBZ Intersil | по запросу |
Корпус | 8 Ld SOIC |
Точность | В±5 ppm |
Alarms | 1 |
Battery Backup | Yes |
Battery Seal | Yes |
CPU Supervisory Function POR | No |
CPU Supervisory Function Watchdog Timer | No |
Crystal Frequency Trimming | Yes |
Description | Low Power RTC with Battery-Backed SRAM and Embedded Temp Comp ?5ppm with Auto Day Light Saving |
FOUT | IRQ_bar/FOUT |
Freq. Out Pin | Yes |
IBAT | 1000 nA |
IRQ Pin | Yes |
IRQ_Bar | IRQ_bar/FOUT |
Memory Type | RAM |
Oscillator Compensation (ppm) | -336 to +337 |
Other Functions | Battery Switchover Time Stamp, Battery Status Monitor, Brown-out Alarm, Daylight Savings |
Peak Temp | 260°C |
RESET_bar | No |
Reset | No |
SRAM | 128 Bytes |
Selectable Frequency Output | 15 |
Tamper Detect | No |
Time Keeping Current | 3.5 μA |
Timer | No |
VBAT (max) | 5.5 V |
VBAT (min) | 1.8 V |
VCC (max) | 5.5 V |
VCC (min) | 2.7 V |
VTRIP for POR | 6 Select VTRIP Levels |
Интерфейс | I2C |
Серия: ISL12022 (3)
- ISL12022IBZ ISL12022IBZ-T ISL12022IBZ-T7A
- Timing & Digital ICs > Real Time Clocks > Real Time Clocks
