Datasheet Intersil ISL1209 — Даташит
ПроизводительIntersil
СерияISL1209
RTC с низким энергопотреблением, SRAM с батарейным питанием и обнаружением событий
ISL1209 Datasheet
PDF, 1.0 Мб, Версия: 2017-11-02
Real Time Clock (RTC) IC Time Event Recorder 2B I2C, 2-Wire Serial 10-TFSOP, 10-MSOP (0.118, 3.00mm Width)
ISL1209IU10
Intersil
65 ₽
ISL1209EVAL
Intersil
Hi-Tech Circuit Group
ISL1209IU10
ISL1209
Intersil
ISL1209IU10ISL1209IU10-TKISL1209IU10-ZTKISL1209IU10ZISL1209IU10Z-TK
N12345
Корпус10 Ld MSOP10 Ld MSOP T+R10 Ld MSOP10 Ld MSOP T+R
Parameters / ModelsISL1209IU10ISL1209IU10-TKISL1209IU10-ZTKISL1209IU10ZISL1209IU10Z-TK
Alarms11111
Battery BackupYesYesYesYesYes
Battery SealYesYesYesYesYes
CPU Supervisory Function PORNoNoNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNoNoNo
Crystal Frequency TrimmingYesYesYesYesYes
DescriptionLow Power RTC with Battery Backed SRAM and Event DetectionLow Power RTC with Battery Backed SRAM and Event DetectionLow Power RTC with Battery Backed SRAM and Event DetectionLow Power RTC with Battery Backed SRAM and Event DetectionLow Power RTC with Battery Backed SRAM and Event Detection
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYesYesYes
IBAT400 nA400 nA400 nA400 nA400 nA
IRQ PinYesYesYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeRAMRAMRAMRAMRAM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-94 to +140-94 to +140-94 to +140-94 to +140-94 to +140
Other FunctionsEvent DetectEvent DetectEvent DetectEvent DetectEvent Detect
Peak Temp240°C240°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandard
RESET_barNoNoNoNoNo
ResetNoNoNoNoNo
SRAM2 Bytes2 Bytes2 Bytes2 Bytes2 Bytes
Selectable Frequency Output1515151515
Tamper DetectYesYesYesYesYes
Time Keeping Current1.2 μA1.2 μA1.2 μA1.2 μA1.2 μA
TimerNoNoNoNoNo
VBAT (max)5.5 V5.5 V5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V2.7 V
VTRIP for PORYesYesYesYesYes
ИнтерфейсI2CI2CI2CI2CI2C
RoHSСовместимСовместим
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL1209
