Datasheet Intersil ISL12024 — Даташит
Производитель | Intersil |
Серия | ISL12024 |
Часы/календарь реального времени со встроенным уникальным идентификатором
27 предложений от 19 поставщиков Микросхема часы реального времени, Pb-Free, RTC, output programmed to 32kHz with EEPROM in 8 pi HT SUSA CODE:8542390000 | |||
ISL12024IRTCZ Renesas | 76 ₽ | ||
ISL12024IRTCZ-T Intersil | 146 ₽ | ||
ISL12024IBZ Renesas | по запросу | ||
ISL12024IRTCZ Intersil | по запросу |
ISL12024IBZ | ISL12024IBZ-T | ISL12024IVZ | ISL12024IVZ-T | |
N | 1 | 2 | 3 | 4 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld TSSOP | 8 Ld TSSOP T+R |
Parameters / Models | ISL12024IBZ | ISL12024IBZ-T | ISL12024IVZ | ISL12024IVZ-T |
Alarms | 2 | 2 | 2 | 2 |
Battery Backup | Yes | Yes | Yes | Yes |
Battery Seal | Yes | Yes | Yes | Yes |
CPU Supervisory Function POR | No | No | No | No |
CPU Supervisory Function Watchdog Timer | No | No | No | No |
Crystal Frequency Trimming | Yes | Yes | Yes | Yes |
Description | Real-Time Clock/Calendar with Embedded Unique ID | Real-Time Clock/Calendar with Embedded Unique ID | Real-Time Clock/Calendar with Embedded Unique ID | Real-Time Clock/Calendar with Embedded Unique ID |
FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT |
Freq. Out Pin | Yes | Yes | Yes | Yes |
IBAT | 850 nA | 850 nA | 850 nA | 850 nA |
IRQ Pin | Yes | Yes | Yes | Yes |
IRQ_Bar | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT | IRQ_bar/FOUT |
Memory Type | EEPROM | EEPROM | EEPROM | EEPROM |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Oscillator Compensation (ppm) | -336 to +337 | -336 to +337 | -336 to +337 | -336 to +337 |
Other Functions | 64-bit Unique ID | 64-bit Unique ID | 64-bit Unique ID | 64-bit Unique ID |
Peak Temp | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard |
RESET_bar | No | No | No | No |
Reset | No | No | No | No |
SRAM | 512x8-Bit EEPROM | 512x8-Bit EEPROM | 512x8-Bit EEPROM | 512x8-Bit EEPROM |
Selectable Frequency Output | 3 | 3 | 3 | 3 |
Tamper Detect | No | No | No | No |
Time Keeping Current | 3 μA | 3 μA | 3 μA | 3 μA |
VBAT (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VBAT (min) | 1.8 V | 1.8 V | 1.8 V | 1.8 V |
VCC (max) | 5.5 V | 5.5 V | 5.5 V | 5.5 V |
VCC (min) | 2.7 V | 2.7 V | 2.7 V | 2.7 V |
Интерфейс | I2C | I2C | I2C | I2C |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: ISL12024 (4)
- Timing & Digital ICs > Real Time Clocks > Real Time Clocks
