Datasheet Intersil ISL1218 — Даташит
ПроизводительIntersil
СерияISL1218
RTC с низким энергопотреблением и SRAM с батарейным питанием
ISL1218 Datasheet
PDF, 899 Кб, Версия: 2017-12-01
27 предложений от 18 поставщиков
Микросхема часы реального времени, Real Time Clock Serial 8Byte Clock/Calendar/Alarm/Battery Backup Automotive 8Pin SOIC N Tube
ISL1218IUZ
Renesas
60 ₽
727GS
ISL1218IBZ
Renesas
от 732 ₽
ТаймЧипс
ISL1218IBZ-T
Intersil
LifeElectronics
ISL1218IUZ
Intersil
ISL1218IBZISL1218IBZ-TISL1218IUZISL1218IUZ-T
N1234
Корпус8 Ld SOIC8 Ld SOIC T+R8 Ld MSOP8 Ld MSOP T+R
Parameters / ModelsISL1218IBZISL1218IBZ-TISL1218IUZISL1218IUZ-T
Alarms1111
Battery BackupYesYesYesYes
Battery SealYesYesYesYes
CPU Supervisory Function PORNoNoNoNo
CPU Supervisory Function Watchdog TimerNoNoNoNo
Crystal Frequency TrimmingYesYesYesYes
DescriptionLow Power RTC with Battery Backed SRAMLow Power RTC with Battery Backed SRAMLow Power RTC with Battery Backed SRAMLow Power RTC with Battery Backed SRAM
FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Freq. Out PinYesYesYesYes
IBAT400 nA400 nA400 nA400 nA
IRQ PinYesYesYesYes
IRQ_BarIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUTIRQ_bar/FOUT
Memory TypeRAMRAMRAMRAM
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85
Oscillator Compensation (ppm)-94 to +140-94 to +140-94 to +140-94 to +140
Peak Temp260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandard
RESET_barNoNoNoNo
ResetNoNoNoNo
SRAM8 Bytes8 Bytes8 Bytes8 Bytes
Selectable Frequency Output15151515
Tamper DetectNoNoNoNo
Time Keeping Current1.2 μA1.2 μA1.2 μA1.2 μA
TimerNoNoNoNo
VBAT (max)5.5 V5.5 V5.5 V5.5 V
VBAT (min)1.8 V1.8 V1.8 V1.8 V
VCC (max)5.5 V5.5 V5.5 V5.5 V
VCC (min)2.7 V2.7 V2.7 V2.7 V
VTRIP for PORYesYesYesYes
ИнтерфейсI2CI2CI2CI2C
RoHSСовместимСовместимСовместимСовместим
  • Timing & Digital ICs > Real Time Clocks > Real Time Clocks
На английском языке: Datasheet Intersil ISL1218
