Линейка продуктов KEEN SIDE
Datasheet Intersil EL7156 — Даташит
ПроизводительIntersil
СерияEL7156
Высокопроизводительный драйвер штыря
EL7156 Datasheet
PDF, 563 Кб, Версия: 2017-10-12
51 предложений от 26 поставщиков
Интегральные схемы (ИС) усилителей мощности EL7156CSZ 40 MHZ PIN DRVR W/LVL SHIFTER
EL7156CSZ-T7
Renesas
39 ₽
EL7156CSZ-T
Intersil
229 ₽
EL7156
Intersil
EL7156CSZ
Intersil
EL7156CNEL7156CNZEL7156CSEL7156CS-T13EL7156CS-T7EL7156CSZEL7156CSZ-T13EL7156CSZ-T7EL7156CSZ-T7A
N123456789
Корпус8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsEL7156CNEL7156CNZEL7156CSEL7156CS-T13EL7156CS-T7EL7156CSZEL7156CSZ-T13EL7156CSZ-T7EL7156CSZ-T7A
# of Drivers111111111
DescriptionHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin Driver
Fall Time15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns
IS3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Input Signal Range (V)0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP
Input Supply Range VP (V)+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5
Max Operating Frequency40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Signal Range (V)-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16
Peak Output Current IPK3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A
Peak Temp240°C240°C240°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandard
RON2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©
Rise Time14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns
Turn Off Delay (ns)9.59.59.59.59.59.59.59.59.5
Turn On Delay (ns)101010101010101010
VBIAS (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VIN (max) (V)16.516.516.516.516.516.516.516.516.5
RoHSСовместимСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > PowerFet/CCD drivers
На английском языке: Datasheet Intersil EL7156
