Datasheet Intersil EL7155 — Даташит
ПроизводительIntersil
СерияEL7155
Высокопроизводительный драйвер штыря
EL7155 Datasheet
PDF, 531 Кб, Версия: 2017-10-12
38 предложений от 22 поставщиков
Мультифункциональные Драйверы
EL7155CN
Intersil
537 ₽
EL7155CSZ
Renesas
от 906 ₽
EL7155CSZ-T7
Intersil
TradeElectronics
EL7155CS-T7
Intersil
EL7155CNEL7155CSEL7155CS-T13EL7155CS-T7EL7155CSZEL7155CSZ-T13EL7155CSZ-T7EL7155CSZ-T7A
N12345678
Корпус8 Ld PDIP8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsEL7155CNEL7155CSEL7155CS-T13EL7155CS-T7EL7155CSZEL7155CSZ-T13EL7155CSZ-T7EL7155CSZ-T7A
# of Drivers11111111
DescriptionHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin DriverHigh Performance Pin Driver
Fall Time15 ns15 ns15 ns15 ns15 ns15 ns15 ns15 ns
IS3 mA3 mA3 mA3 mA3 mA3 mA3 mA3 mA
Input Signal Range (V)0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP
Input Supply Range VP (V)+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5+4.5 to +16.5
Max Operating Frequency40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz40 MHz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Signal Range (V)-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16-5 to +16
Peak Output Current IPK3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A3.5 A
Peak Temp240°C240°C240°C260°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
RON2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©2.7 О©
Rise Time14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns14.5 ns
Turn Off Delay (ns)9.59.59.59.59.59.59.59.5
Turn On Delay (ns)1010101010101010
VBIAS (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VIN (max) (V)16.516.516.516.516.516.516.516.5
RoHSСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > PowerFet/CCD drivers
На английском языке: Datasheet Intersil EL7155
