Линейка продуктов KEEN SIDE
Datasheet Intersil EL7154 — Даташит
ПроизводительIntersil
СерияEL7154
Высокоскоростной монолитный штифтовый драйвер
EL7154 Datasheet
PDF, 507 Кб, Версия: 2017-10-11
29 предложений от 24 поставщиков
Интегральные схемы (ИС) усилителей мощности EL7154CSZ 10MHZ PIN DRVR W/DISABLE
EL7154CSZ
Renesas
132 ₽
EL7154CS-T13
Renesas
205 ₽
727GS
EL7154CS
Intersil
376 ₽
TradeElectronics
EL7154CSZ-T13
Intersil
EL7154CNEL7154CNZEL7154CSEL7154CS-T13EL7154CS-T7EL7154CSZEL7154CSZ-T13EL7154CSZ-T7
N12345678
Корпус8 Ld PDIP8 Ld PDIP8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R8 Ld SOIC8 Ld SOIC T+R8 Ld SOIC T+R
Parameters / ModelsEL7154CNEL7154CNZEL7154CSEL7154CS-T13EL7154CS-T7EL7154CSZEL7154CSZ-T13EL7154CSZ-T7
# of Drivers11111111
DescriptionHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin DriverHigh Speed, Monolithic Pin Driver
Fall Time20 ns20 ns20 ns20 ns20 ns20 ns20 ns20 ns
IS2.5 mA2.5 mA2.5 mA2.5 mA2.5 mA2.5 mA2.5 mA2.5 mA
Input Signal Range (V)0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP0 to VP
Input Supply Range VP (V)+4.5 to +16+4.5 to +16+4.5 to +16+4.5 to +16+4.5 to +16+4.5 to +16+4.5 to +16+4.5 to +16
Max Operating Frequency10 MHz10 MHz10 MHz10 MHz10 MHz10 MHz10 MHz10 MHz
Рабочий диапазон температурот -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Output Signal Range (V)-3 to +16-3 to +16-3 to +16-3 to +16-3 to +16-3 to +16-3 to +16-3 to +16
Peak Output Current IPK4 A4 A4 A4 A4 A4 A4 A4 A
Peak Temp240°C240°C240°C260°C260°C260°C
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
RON1.5 О©1.5 О©1.5 О©1.5 О©1.5 О©1.5 О©1.5 О©1.5 О©
Rise Time20 ns20 ns20 ns20 ns20 ns20 ns20 ns20 ns
Turn Off Delay (ns)2020202020202020
Turn On Delay (ns)1010101010101010
VBIAS (min)4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V4.5 V
VIN (max) (V)1616161616161616
RoHSСовместимСовместимСовместимСовместим
  • Amplifiers & Buffers > All Amplifiers > PowerFet/CCD drivers
На английском языке: Datasheet Intersil EL7154
