Datasheet Intersil EL7158 — Даташит
Производитель | Intersil |
Серия | EL7158 |
Драйвер контактов сверхсильного тока
![]() 44 предложений от 24 поставщиков Интегральные схемы (ИС) усилителей мощности EL1758ISZ ULTRA HI CUR PIN DRVR | |||
EL7158ISZ-T13 Renesas | от 428 ₽ | ||
EL7158ISZ Intersil | по запросу | ||
EL7158IS-T7 Intersil | по запросу | ||
EL7158ISZ-T7 Intersil | по запросу |
EL7158IS | EL7158IS-T13 | EL7158IS-T7 | EL7158ISZ | EL7158ISZ-T13 | EL7158ISZ-T7 | EL7158ISZ-T7A | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
Корпус | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC T+R | 8 Ld SOIC T+R |
Parameters / Models | EL7158IS | EL7158IS-T13 | EL7158IS-T7 | EL7158ISZ | EL7158ISZ-T13 | EL7158ISZ-T7 | EL7158ISZ-T7A |
# of Drivers | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Description | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver | Ultra-High Current Pin Driver |
Fall Time | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns |
IS | 2.5 mA | 2.5 mA | 2.5 mA | 2.5 mA | 2.5 mA | 2.5 mA | 2.5 mA |
Input Signal Range (V) | 0 to VP | 0 to VP | 0 to VP | 0 to VP | 0 to VP | 0 to VP | 0 to VP |
Input Supply Range VP (V) | +4.5 to +18 | +4.5 to +18 | +4.5 to +18 | +4.5 to +18 | +4.5 to +18 | +4.5 to +18 | +4.5 to +18 |
Max Operating Frequency | 40 MHz | 40 MHz | 40 MHz | 40 MHz | 40 MHz | 40 MHz | 40 MHz |
Рабочий диапазон температур | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Output Signal Range (V) | -5 to +12 | -5 to +12 | -5 to +12 | -5 to +12 | -5 to +12 | -5 to +12 | -5 to +12 |
Peak Output Current IPK | 12 A | 12 A | 12 A | 12 A | 12 A | 12 A | 12 A |
Peak Temp | 240°C | 240°C | 240°C | 260°C | 260°C | 260°C | 260°C |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
RON | 0.5 О© | 0.5 О© | 0.5 О© | 0.5 О© | 0.5 О© | 0.5 О© | 0.5 О© |
Rise Time | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns | 12 ns |
Turn Off Delay (ns) | 22.5 | 22.5 | 22.5 | 22.5 | 22.5 | 22.5 | 22.5 |
Turn On Delay (ns) | 22 | 22 | 22 | 22 | 22 | 22 | 22 |
VBIAS (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
VIN (max) (V) | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
RoHS | Совместим | Совместим | Совместим | Совместим |
Серия: EL7158 (7)
- Amplifiers & Buffers > All Amplifiers > PowerFet/CCD drivers
