Datasheet Intersil HA-2525 — Даташит
| Производитель | Intersil |
| Серия | HA-2525 |
20 МГц, высокая скорость нарастания напряжения, некомпенсированные, высокий входной импеданс, операционные усилители
| 9 предложений от 9 поставщиков 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | |||
| HA2525-5 | по запросу | ||
| HA252-5 | по запросу | ||
| HA252.5A | по запросу | ||
| HA2-2525-5 | HA2-2525-5ZR5254 | HA3-2525-5 | HA3-2525-5Z | HA7-2525-5 | HA9P2525-5 | HA9P2525-5Z | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
| Корпус | 8 Ld CAN | 8 Ld CAN | 8 Ld PDIP | 8 Ld PDIP | 8 Ld CERDIP | 8 Ld SOIC | 8 Ld SOIC |
| Parameters / Models | HA2-2525-5 | HA2-2525-5ZR5254 | HA3-2525-5 | HA3-2525-5Z | HA7-2525-5 | HA9P2525-5 | HA9P2525-5Z |
| AVOL | 84 dB | 84 dB | 84 dB | 84 dB | 84 dB | 84 dB | 84 dB |
| Полоса частот | 20 MHz | 20 MHz | 20 MHz | 20 MHz | 20 MHz | 20 MHz | 20 MHz |
| Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Коэффициент подавления синфазного сигнала | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB |
| Description | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers | 20MHz, High Slew Rate, Uncompensated, High Input Impedance, Operational Amplifiers |
| Enable | No | No | No | No | No | No | No |
| Gain AV (min) | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| IBIAS | 125 nA | 125 nA | 125 nA | 125 nA | 125 nA | 125 nA | 125 nA |
| IBIAS (max) | 250 nA | 250 nA | 250 nA | 250 nA | 250 nA | 250 nA | 250 nA |
| IOUT | 10 mA | 10 mA | 10 mA | 10 mA | 10 mA | 10 mA | 10 mA |
| IS (per amp) | 4 mA | 4 mA | 4 mA | 4 mA | 4 mA | 4 mA | 4 mA |
| Noise VN | 20 nV/√Hz | 20 nV/√Hz | 20 nV/√Hz | 20 nV/√Hz | 20 nV/√Hz | 20 nV/√Hz | 20 nV/√Hz |
| Рабочий диапазон температур | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 |
| Output Headroom | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V | 3 V |
| PSRR | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB | 90 dB |
| Peak Temp | 240°C | 260°C | |||||
| Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
| Rail-to-Rail Input | No | No | No | No | No | No | No |
| Rail-to-Rail Output | No | No | No | No | No | No | No |
| Скорость нарастания | 120 V/μs | 120 V/μs | 120 V/μs | 120 V/μs | 120 V/μs | 120 V/μs | 120 V/μs |
| Thermal Shutdown | No | No | No | No | No | No | No |
| Topology | VFA | VFA | VFA | VFA | VFA | VFA | VFA |
| VOS (max) | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV | 10 mV |
| VOUT | 24 V | 24 V | 24 V | 24 V | 24 V | 24 V | 24 V |
| VS (max) | 36 V | 36 V | 36 V | 36 V | 36 V | 36 V | 36 V |
| VS (min) | 16 V | 16 V | 16 V | 16 V | 16 V | 16 V | 16 V |
| RoHS | Совместим | Совместим | Совместим |
Серия: HA-2525 (7)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
