Datasheet Intersil CA5260 — Даташит
Производитель | Intersil |
Серия | CA5260 |
Два микропроцессорных операционных усилителя BiMOS 3 МГц с входом MOSFET/выходом CMOS
![]() 23 предложений от 22 поставщиков , 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output | |||
CA5260M Renesas | 131 ₽ | ||
CA5260MZ Intersil | по запросу | ||
CA5260M* Intersil | по запросу | ||
CA5260_05 Intersil | по запросу |
CA5260E | CA5260M | CA5260M96 | CA5260MZ | CA5260MZ96 | |
N | 1 | 2 | 3 | 4 | 5 |
Корпус | 8 Ld PDIP | 8 Ld SOIC | 8 Ld SOIC T+R | 8 Ld SOIC | 8 Ld SOIC T+R |
Parameters / Models | CA5260E | CA5260M | CA5260M96 | CA5260MZ | CA5260MZ96 |
AVOL | 110 dB | 110 dB | 110 dB | 110 dB | 110 dB |
Полоса частот | 3 MHz | 3 MHz | 3 MHz | 3 MHz | 3 MHz |
Количество каналов | 2 | 2 | 2 | 2 | 2 |
Коэффициент подавления синфазного сигнала | 85 dB | 85 dB | 85 dB | 85 dB | 85 dB |
Description | Dual 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output | Dual 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output | Dual 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output | Dual 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output | Dual 3MHz, BiMOS Microprocessor Operational Amplifiers with MOSFET Input/CMOS Output |
Enable | No | No | No | No | No |
Gain AV (min) | 1 | 1 | 1 | 1 | 1 |
IBIAS | 2 pA | 2 pA | 2 pA | 2 pA | 2 pA |
IBIAS (max) | 15 pA | 15 pA | 15 pA | 15 pA | 15 pA |
IOUT | 22 mA | 22 mA | 22 mA | 22 mA | 22 mA |
IS (per amp) | 1.8 mA | 1.8 mA | 1.8 mA | 1.8 mA | 1.8 mA |
Noise VN | 25 nV/√Hz | 25 nV/√Hz | 25 nV/√Hz | 25 nV/√Hz | 25 nV/√Hz |
Рабочий диапазон температур | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
PSRR | 84 dB | 84 dB | 84 dB | 84 dB | 84 dB |
Peak Temp | 240°C | 240°C | 260°C | 260°C | |
Qualification Level | Standard | Standard | Standard | Standard | Standard |
Rail-to-Rail Input | No | No | No | No | No |
Rail-to-Rail Output | Yes | Yes | Yes | Yes | Yes |
Скорость нарастания | 5 V/μs | 5 V/μs | 5 V/μs | 5 V/μs | 5 V/μs |
Thermal Shutdown | No | No | No | No | No |
VOS (max) | 6 mV | 6 mV | 6 mV | 6 mV | 6 mV |
VOUT | 15 V | 15 V | 15 V | 15 V | 15 V |
VS (max) | 16 V | 16 V | 16 V | 16 V | 16 V |
VS (min) | 4.5 V | 4.5 V | 4.5 V | 4.5 V | 4.5 V |
Серия: CA5260 (5)
- Amplifiers & Buffers > All Amplifiers > Amplifiers
