Datasheet Intersil ISL78302 — Даташит
ПроизводительIntersil
СерияISL78302
Двойной LDO с низким уровнем шума, высокой производительностью и низким I Q
ISL78302 Datasheet
PDF, 755 Кб, Версия: 2017-10-25
ISL78302AR1AZISL78302ARBFZISL78302ARBFZ-TISL78302ARBNZISL78302ARBNZ-TISL78302ARCWZISL78302ARCWZ-TISL78302ARFBZISL78302ARFBZ-TISL78302ARFWZISL78302ARFWZ-TISL78302ARNBZISL78302ARNBZ-TISL78302ARNWZISL78302ARNWZ-TISL78302ARWCZISL78302ARWCZ-T
N1234567891011121314151617
Корпус10 Ld DFN10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R
Parameters / ModelsISL78302AR1AZISL78302ARBFZISL78302ARBFZ-TISL78302ARBNZISL78302ARBNZ-TISL78302ARCWZISL78302ARCWZ-TISL78302ARFBZISL78302ARFBZ-TISL78302ARFWZISL78302ARFWZ-TISL78302ARNBZISL78302ARNBZ-TISL78302ARNWZISL78302ARNWZ-TISL78302ARWCZISL78302ARWCZ-T
# of PORs22222222222222222
DescriptionDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQDual LDO with Low Noise, High Performance and Low IQ
Enable/ShutdownYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Fixed Output Voltage OptionYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
IOUT1 (max) (A)0.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.3
IOUT2 (max) (A)0.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.3
IQ47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA
NeedsExternalBiasNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Noise (ОјVRMS 10Hz to 100kHz)3737373737373737373737373737373737
O/P Voltage Accuracy (%)В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8
Рабочий диапазон температурот -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105
PGOOD OutputYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
PSRR64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB64 dB
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotive
Typical Drop-Out Voltage (mV)150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA150 @ 150mA
VIN (max) (V)6.56.56.56.56.56.56.56.56.56.56.56.56.56.56.56.56.5
VIN (min) (V)2.32.32.32.32.32.32.32.32.32.32.32.32.32.32.32.32.3
VOUT (max) (V)3.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.3
VOUT (min) (V)1.21.21.21.21.21.21.21.21.21.21.21.21.21.21.21.21.2
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • End Market Specific > Automotive ICs > Linear Regulators
На английском языке: Datasheet Intersil ISL78302
Политика конфиденциальности
