Datasheet Intersil ISL78302A — Даташит
ПроизводительIntersil
СерияISL78302A
Двойной LDO с низким уровнем шума, очень высоким PSRR и низким I Q
ISL78302A Datasheet
PDF, 625 Кб, Версия: 2017-10-25
31 предложений от 14 поставщиков
Микросхемы управления электропитанием - Стабилизаторы напряжения - Линейные
ISL78302AARBJZ
Intersil
55 ₽
ISL78302AARBJZ
Renesas
84 ₽
ISL78302AARBJZ
Hi-Tech Circuit Group
ISL78302AARBJZ
ISL78302AARBJZISL78302AARBJZ-TISL78302AARGCZISL78302AARGCZ-TISL78302AARJCZISL78302AARJCZ-TISL78302AARJMZISL78302AARJMZ-TISL78302AARJRZISL78302AARJRZ-TISL78302AARLLZISL78302AARLLZ-TISL78302AARMMZISL78302AARMMZ-TISL78302AARPLZISL78302AARPLZ-T
N12345678910111213141516
Корпус10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R10 Ld DFN10 Ld DFN T+R
Parameters / ModelsISL78302AARBJZISL78302AARBJZ-TISL78302AARGCZISL78302AARGCZ-TISL78302AARJCZISL78302AARJCZ-TISL78302AARJMZISL78302AARJMZ-TISL78302AARJRZISL78302AARJRZ-TISL78302AARLLZISL78302AARLLZ-TISL78302AARMMZISL78302AARMMZ-TISL78302AARPLZISL78302AARPLZ-T
# of PORs2222222222222222
DescriptionDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQDual LDO with Low Noise, Very High PSRR and Low IQ
Enable/ShutdownYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Fixed Output Voltage OptionYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
IOUT1 (max) (A)0.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.3
IOUT2 (max) (A)0.30.30.30.30.30.30.30.30.30.30.30.30.30.30.30.3
IQ47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA47 μA
NeedsExternalBiasNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Noise (ОјVRMS 10Hz to 100kHz)30303030303030303030303030303030
O/P Voltage Accuracy (%)В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8В±1.8
Рабочий диапазон температурот -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105от -40 до 105
PGOOD OutputYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
PSRR90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB90 dB
Peak Temp260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C260°C
Qualification LevelAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotiveAutomotive
Typical Drop-Out Voltage (mV)115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA115 @ 150mA
VIN (max) (V)6.56.56.56.56.56.56.56.56.56.56.56.56.56.56.56.5
VIN (min) (V)2.32.32.32.32.32.32.32.32.32.32.32.32.32.32.32.3
VOUT (max) (V)3333333333333333
VOUT (min) (V)1.51.51.51.51.51.51.51.51.51.51.51.51.51.51.51.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • End Market Specific > Automotive ICs > Linear Regulators
На английском языке: Datasheet Intersil ISL78302A
