Datasheet Intersil HC55185 — Даташит
Производитель | Intersil |
Серия | HC55185 |
VoIP-вызов SLIC
![]() 27 предложений от 24 поставщиков ИС управления телекоммуникационными линиями 100V 53DB LB RINGING W/GROUND START | |||
HC55185ECMR4854 Intersil | 235 ₽ | ||
HC55185ECMR4854 Intersil | 403 ₽ | ||
HC55185ECMR4854 | 489 ₽ | ||
HC55185X-SAMPLE Intersil | по запросу |
HC55185AIM | HC55185AIM96 | HC55185AIMZ | HC55185AIMZ96 | HC55185BIM | HC55185BIM96 | HC55185BIMZ | HC55185BIMZ96 | HC55185CCM96 | HC55185CIM | HC55185CIM96 | HC55185CIMZ | HC55185CIMZ96 | HC55185DIM | HC55185DIM96 | HC55185DIMZ | HC55185DIMZ96 | HC55185ECM | HC55185ECM96 | HC55185ECMZ | HC55185ECMZ96 | HC55185ECR | HC55185ECR96 | HC55185ECRZ | HC55185ECRZ96 | HC55185FCM | HC55185FCM96 | HC55185FCMZ | HC55185FCMZ96 | HC55185FCR | HC55185FCR96 | HC55185FCRZ | HC55185FCRZ96 | HC55185GCM | HC55185GCMZ | HC55185GCR | HC55185GCR96 | HC55185GCRZ | HC55185GCRZ96 | HC55185GIM | HC55185GIMZ | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 |
Корпус | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 32 Ld QFN | 32 Ld QFN T+R | 32 Ld QFN | 32 Ld QFN T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 28 Ld PLCC | 28 Ld PLCC T+R | 32 Ld QFN | 32 Ld QFN T+R | 32 Ld QFN | 32 Ld QFN T+R | 28 Ld PLCC | 28 Ld PLCC | 32 Ld QFN | 32 Ld QFN T+R | 32 Ld QFN | 32 Ld QFN T+R | 28 Ld PLCC | 28 Ld PLCC |
Parameters / Models | HC55185AIM | HC55185AIM96 | HC55185AIMZ | HC55185AIMZ96 | HC55185BIM | HC55185BIM96 | HC55185BIMZ | HC55185BIMZ96 | HC55185CCM96 | HC55185CIM | HC55185CIM96 | HC55185CIMZ | HC55185CIMZ96 | HC55185DIM | HC55185DIM96 | HC55185DIMZ | HC55185DIMZ96 | HC55185ECM | HC55185ECM96 | HC55185ECMZ | HC55185ECMZ96 | HC55185ECR | HC55185ECR96 | HC55185ECRZ | HC55185ECRZ96 | HC55185FCM | HC55185FCM96 | HC55185FCMZ | HC55185FCMZ96 | HC55185FCR | HC55185FCR96 | HC55185FCRZ | HC55185FCRZ96 | HC55185GCM | HC55185GCMZ | HC55185GCR | HC55185GCR96 | HC55185GCRZ | HC55185GCRZ96 | HC55185GIM | HC55185GIMZ |
Description | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC | VoIP Ringing SLIC |
High Battery Voltage | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 | 100/85/75 |
Integ. Battery Switch | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X |
Long. Balance | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB | 58/53 dB |
Loop Current (max) | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA | 45 mA |
Loop Current (min) | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA | 15 mA |
Рабочий диапазон температур | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet | от Comm, Ind, See Datasheet |
Peak Temp | 225°C | 225°C | 245°C | 245°C | 225°C | 225°C | 245°C | 245°C | 225°C | 225°C | 245°C | 245°C | 225°C | 225°C | 245°C | 245°C | 225°C | 225°C | 245°C | 245°C | 240°C | 240°C | 260°C | 260°C | 225°C | 225°C | 245°C | 245°C | 240°C | 240°C | 260°C | 260°C | 225°C | 245°C | 240°C | 240°C | 260°C | 260°C | 225°C | 245°C | |
Polarity Reversal | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X | X |
Qualification Level | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard | Standard |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: HC55185 (41)
- HC55185AIM HC55185AIM96 HC55185AIMZ HC55185AIMZ96 HC55185BIM HC55185BIM96 HC55185BIMZ HC55185BIMZ96 HC55185CCM96 HC55185CIM HC55185CIM96 HC55185CIMZ HC55185CIMZ96 HC55185DIM HC55185DIM96 HC55185DIMZ HC55185DIMZ96 HC55185ECM HC55185ECM96 HC55185ECMZ HC55185ECMZ96 HC55185ECR HC55185ECR96 HC55185ECRZ HC55185ECRZ96 HC55185FCM HC55185FCM96 HC55185FCMZ HC55185FCMZ96 HC55185FCR HC55185FCR96 HC55185FCRZ HC55185FCRZ96 HC55185GCM HC55185GCMZ HC55185GCR HC55185GCR96 HC55185GCRZ HC55185GCRZ96 HC55185GIM HC55185GIMZ
- End Market Specific > Communications ICs > General Purpose Ringing SLICs
