Datasheet Intersil HI-201HS — Даташит
ПроизводительIntersil
СерияHI-201HS
Высокоскоростной, Quad SPST, аналоговый КМОП-переключатель
Datasheet
PDF, 713 Кб
High-Speed, CMOS, Quad, SPST Analog Switch
МосЧип
HI-201HS/883C
Maxim
LifeElectronics
HI201HS
Intersil
HI201HS-5
TradeElectronics
HI-201HS/883
Maxim
HI1-0201HS-2HI1-0201HS-4HI1-0201HS-5HI3-0201HS-5HI3-0201HS-5ZHI9P0201HS-5HI9P0201HS-5ZHI9P0201HS-9HI9P0201HS-9Z
N123456789
Intersil F16.3Intersil F16.3Intersil F16.3Intersil E16.3Intersil E16.3Intersil M16.3Intersil M16.3Intersil M16.3Intersil M16.3
Корпус16 Ld CERDIP
Габаритный чертеж корпуса
16 Ld CERDIP
16 Ld CERDIP
16 Ld PDIP
16 Ld PDIP
16 Ld SOIC
16 Ld SOIC
16 Ld SOIC
16 Ld SOIC
Индекс корпусаF16.3F16.3F16.3E16.3E16.3M16.3M16.3M16.3M16.3
Пиковая температура пайки240°C260°C240°C260°C
Количество выводов161616161616161616
СемействоCERDIPCERDIPCERDIPPDIPPDIPSOICWSOICWSOICWSOICW
Parameters / ModelsHI1-0201HS-2
HI1-0201HS-2
HI1-0201HS-4
HI1-0201HS-4
HI1-0201HS-5
HI1-0201HS-5
HI3-0201HS-5
HI3-0201HS-5
HI3-0201HS-5Z
HI3-0201HS-5Z
HI9P0201HS-5
HI9P0201HS-5
HI9P0201HS-5Z
HI9P0201HS-5Z
HI9P0201HS-9
HI9P0201HS-9
HI9P0201HS-9Z
HI9P0201HS-9Z
Количество каналов444444444
Chg Inj10 pC10 pC10 pC10 pC10 pC10 pC10 pC10 pC10 pC
ConfigurationNCNCNCNCNCNCNCNCNC
DescriptionHigh-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)High-Speed, Quad SPST, CMOS Analog Switch (4 NC)
Drain Cap30 pF30 pF30 pF30 pF30 pF30 pF30 pF30 pF30 pF
IS4.5 mA4.5 mA4.5 mA4.5 mA4.5 mA4.5 mA4.5 mA4.5 mA4.5 mA
Leakage0.3 nA0.3 nA0.3 nA0.3 nA0.3 nA0.3 nA0.3 nA0.3 nA0.3 nA
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandardStandard
Source Cap10 pF10 pF10 pF10 pF10 pF10 pF10 pF10 pF10 pF
Switch or MUXSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitchSwitch
TOFF40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns40 ns
TON30 ns30 ns30 ns30 ns30 ns30 ns30 ns30 ns30 ns
Type of SwitchSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPSTSPST
VCC (Dual) (max)В±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 VВ±15 V
VCC (Dual) (min)В±10 VВ±10 VВ±10 VВ±10 VВ±10 VВ±10 VВ±10 VВ±10 VВ±10 V
VCC (Single) (max)15 V15 V15 V15 V15 V15 V15 V15 V15 V
rDS(ON)30 Ω30 Ω30 Ω30 Ω30 О©30 Ω30 О©30 Ω30 О©
  • Space & Harsh Environment > Harsh Environment > Switches/MUXs/Crosspoints
На английском языке: Datasheet Intersil HI-201HS
