Datasheet Toshiba TC35679FSG-002 — Даташит
ПроизводительToshiba
СерияTC35679FSG-002
МодельTC35679FSG-002
ARM Cortex-M0/импеданс 50 Ом для RF IO/преобразователя постоянного тока/режим низкого энергопотребления (4 уровня).
TC35679FSG-002 Data sheet/English
PDF, 589 Кб
TC35679FSG-002
Toshiba
Bluetooth IC
Код корпуса производителяP-VQFN40-0505-0.40-005/F01
Assembly basesTaiwan
Automotive SupportN/A
Bluetooth CategoryBluetooth low energy
Bluetooth Core spec.4.2
Current Consumption in Deep Sleep mode0.05 мкА
Current Consumption in RX Active mode (peak) [(3.0V)]3.3 мА
Current Consumption in Sleep mode1.8 мкА
Current Consumption in TX Active mode (peak) [(3.0V, TX -0dBm)]3.3 мА
Embedded ProfilesGATT / SMP
FeatureUltra-low power / LE single / Scatternet support / Standalone mode support / Small QFN package / LE Data Length Extension support / LE Secure Connection supoort
FunctionARM Cortex-M0 / 50ohm impedance for RF IO / DC-DC converter / low power mode(4 level)
InterfacingI2C / SPI / UART / PWM / ADC / SWD
Operating Temperature (Max)85 °C
Operating Temperature (Min)-40 °C
Power supply voltage (Max)3.6 В
Power supply voltage (Min)1.8 В
Receiver Sensitivity-93.5 dBm
User Flash Size (KB)N/A
User RAM Size (KB)83
  • Wireless Communications Equipment ICs > Bluetooth wireless communication IC
TC35679FSG002, TC35679FSG 002
На английском языке: Datasheet Toshiba TC35679FSG-002
