Datasheet Intersil ISL8845A — Даташит
ПроизводительIntersil
СерияISL8845A
Высокопроизводительный стандартный в отрасли однотактный ШИМ-контроллер с токовым режимом
ISL8840A, ISL8841A, ISL8842A, ISL8843A, ISL8844A, ISL8845A Datasheet
PDF, 728 Кб, Версия: 2017-10-24
High Performance Industry Standard Single-Ended Current Mode PWM Controller
ISL8845A
Intersil
ISL8845AABZISL8845AABZ-TISL8845AAUZISL8845AAUZ-TISL8845AMBZISL8845AMBZ-TISL8845AMUZISL8845AMUZ-T
N12345678
Intersil M8.15Intersil M8.15Intersil M8.118Intersil M8.118Intersil M8.15Intersil M8.15Intersil M8.118Intersil M8.118
Корпус8 Ld SOIC
Габаритный чертеж корпуса
8 Ld SOIC T+R
8 Ld MSOP
8 Ld MSOP T+R
8 Ld SOIC
8 Ld SOIC T+R
8 Ld MSOP
8 Ld MSOP T+R
Индекс корпусаM8.15M8.15M8.118M8.118M8.15M8.15M8.118M8.118
Пиковая температура пайки260°C260°C260°C260°C260°C260°C260°C260°C
Количество выводов88888888
СемействоSOICNSOICNMSOPMSOPSOICNSOICNMSOPMSOP
Parameters / ModelsISL8845AABZ
ISL8845AABZ
ISL8845AABZ-T
ISL8845AABZ-T
ISL8845AAUZ
ISL8845AAUZ
ISL8845AAUZ-T
ISL8845AAUZ-T
ISL8845AMBZ
ISL8845AMBZ
ISL8845AMBZ-T
ISL8845AMBZ-T
ISL8845AMUZ
ISL8845AMUZ
ISL8845AMUZ-T
ISL8845AMUZ-T
# of PWM Outputs11111111
Control ModePeak Current ModePeak Current ModePeak Current ModePeak Current ModePeak Current ModePeak Current ModePeak Current ModePeak Current Mode
DescriptionHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM ControllerHigh Performance Industry Standard Single-Ended Current Mode PWM Controller
FET Driver IOUT (max)1 A1 A1 A1 A1 A1 A1 A1 A
Max Duty Cycle (%)5050505050505050
No-Load Operating Current2.9 mA2.9 mA2.9 mA2.9 mA2.9 mA2.9 mA2.9 mA2.9 mA
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelStandardStandardStandardStandardStandardStandardStandardStandard
TopologySingle-EndedSingle-EndedSingle-EndedSingle-EndedSingle-EndedSingle-EndedSingle-EndedSingle-Ended
Topology CharacteristicFlybackFlybackFlybackFlybackFlybackFlybackFlybackFlyback
UVLO Falling (V)7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V7.6 V
UVLO Rising (V)8.4 V8.4 V8.4 V8.4 V8.4 V8.4 V8.4 V8.4 V
VBIAS (max)30 V30 V30 V30 V30 V30 V30 V30 V
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
ISL8840A ISL8841A ISL8842A ISL8843A ISL8844A
  • Space & Harsh Environment > Harsh Environment > Isolated PWM Controllers
На английском языке: Datasheet Intersil ISL8845A
