Datasheet Intersil 82C59A — Даташит
Производитель | Intersil |
Серия | 82C59A |
Контроллер приоритетных прерываний CMOS
![]() 27 предложений от 26 поставщиков Чип интерфейса, PERIPH INT CNTRLR 5V 8MHz 28PLCC IND HT SUSA CODE:8542390000 | |||
CS82C59A Intersil | от 10 ₽ | ||
CM82C59A Harris | 47 ₽ | ||
CM82C59A Rochester Electronics | 158 ₽ | ||
CP82C59A Renesas | 2 465 ₽ |
Parameters / Models | CP82C59A![]() | CP82C59A-12![]() | CP82C59A-12Z![]() | CP82C59AZ![]() | CS82C59A![]() | CS82C59A-12![]() | CS82C59A-1296![]() | CS82C59A-12Z![]() | CS82C59A-12Z96![]() | CS82C59A96![]() | CS82C59AZ![]() | CS82C59AZ96![]() | ID82C59A![]() | IS82C59A![]() | IS82C59A-12![]() | IS82C59A-12X96![]() | IS82C59A-12Z![]() | IS82C59A-12Z96![]() | IS82C59AX96![]() | IS82C59AZ![]() | IS82C59AZX96![]() | MD82C59A/7![]() | MD82C59A/B![]() |
Основные особенности | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed | 12.5MHz, 8MHz and 5MHz Versions Available, High Speed |
Qualification Level | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) | QML Class V (space) |
CP82C59A | CP82C59A-12 | CP82C59A-12Z | CP82C59AZ | CS82C59A | CS82C59A-12 | CS82C59A-1296 | CS82C59A-12Z | CS82C59A-12Z96 | CS82C59A96 | CS82C59AZ | CS82C59AZ96 | ID82C59A | IS82C59A | IS82C59A-12 | IS82C59A-12X96 | IS82C59A-12Z | IS82C59A-12Z96 | IS82C59AX96 | IS82C59AZ | IS82C59AZX96 | MD82C59A/7 | MD82C59A/B | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: 82C59A (23)
- Space & Harsh Environment > Harsh Environment > Microprocessors and Peripherals
