Datasheet Intersil HS-26C31RH — Даташит
ПроизводительIntersil
СерияHS-26C31RH
Радиационно-защищенный четырехдифференциальный линейный драйвер
HS-26C31RH, HS-26C31EH Datasheet
PDF, 170 Кб, Версия: 2017-11-08
Radiation Hardened Quad Differential Line Driver
HS-26C31RH
Intersil
HS-26C31RH-T
Intersil
HS1-26C31RH-8HS1-26C31RH-QHS1-26C31RH/PROTOHS9-26C31RH-8HS9-26C31RH-QHS9-26C31RH/PROTOHS9G-26C31RH-QHS9G-26C31RH/PROTO
N12345678
Intersil D16.3Intersil D16.3Intersil D16.3
Корпус16 Ld SBDIP
Габаритный чертеж корпуса
16 Ld SBDIP
16 Ld SBDIP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
Индекс корпусаD16.3D16.3D16.3K16.AK16.AK16.AK16.AK16.A
Количество выводов1616161616161616
СемействоSBDIPSBDIPSBDIPCFPCFPCFPCFPCFP
Parameters / ModelsHS1-26C31RH-8
HS1-26C31RH-8
HS1-26C31RH-Q
HS1-26C31RH-Q
HS1-26C31RH/PROTO
HS1-26C31RH/PROTO
ClassV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTO
DLA SMD5962-966635962-966635962-966635962-966635962-966635962-966635962-966635962-96663
DescriptionRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line DriverRadiation Hardened Quad Differential Line Driver
High Dose Rate (HDR) krad(Si)300300300300300300300300
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelQML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)
SEL (MeV/mg/cm2)100100100100100100100100
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
HS-26C31EH
  • Space & Harsh Environment > Rad Hard Analog > RH Interface
На английском языке: Datasheet Intersil HS-26C31RH
