Datasheet Intersil HS-26CT32RH — Даташит
ПроизводительIntersil
СерияHS-26CT32RH
Радиационно-стойкие четырехдифференциальные линейные приемники
HS-26CT32RH-T Datasheet
PDF, 238 Кб, Версия: 2017-11-08
HS-26CT32RH, HS-26CT32EH Datasheet
PDF, 236 Кб, Версия: 2017-11-08
Radiation Hardened Quad Differential Line Receiver
HS-26CT32RH-T
Intersil
HS1-26CT32RH-8HS1-26CT32RH-QHS1-26CT32RH-THS1-26CT32RH/PROTOHS9-26CT32RH-8HS9-26CT32RH-QHS9-26CT32RH-THS9-26CT32RH/PROTOHS9G-26CT32RH-QHS9G-26CT32RH/PROTO
N12345678910
Intersil D16.3Intersil D16.3Intersil D16.3Intersil D16.3
Корпус16 Ld SBDIP
Габаритный чертеж корпуса
16 Ld SBDIP
16 Ld SBDIP
16 Ld SBDIP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
Индекс корпусаD16.3D16.3D16.3D16.3K16.AK16.AK16.AK16.AK16.AK16.A
Количество выводов16161616161616161616
СемействоSBDIPSBDIPSBDIPSBDIPCFPCFPCFPCFPCFPCFP
Parameters / ModelsHS1-26CT32RH-8
HS1-26CT32RH-8
HS1-26CT32RH-Q
HS1-26CT32RH-Q
HS1-26CT32RH-T
HS1-26CT32RH-T
HS1-26CT32RH/PROTO
HS1-26CT32RH/PROTO
ClassV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTO
DLA SMD5962-956315962-956315962-956315962-956315962-956315962-956315962-956315962-956315962-956315962-95631
DescriptionRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line ReceiversRadiation Hardened Quad Differential Line Receivers
High Dose Rate (HDR) krad(Si)300300300300300300300300300300
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelQML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)QML Class Q (military), QML Class T (space lower level), QML Class V (space)
SEL (MeV/mg/cm2)100100100100100100100100100100
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
HS-26CT32EH
  • Space & Harsh Environment > Rad Hard Analog > RH Interface
На английском языке: Datasheet Intersil HS-26CT32RH
