Datasheet Intersil HS-26C32RH — Даташит
ПроизводительIntersil
СерияHS-26C32RH
Радиационно-стойкий четырехдифференциальный линейный приемник
HS-26C32RH, HS-26C32EH Datasheet
PDF, 256 Кб, Версия: 2017-11-08
Radiation Hardened Quad Differential Line Receiver
ТаймЧипс
HS-26C32RH
Intersil
LifeElectronics
HS-26C32RH-T
Intersil
HS26C32RH-8
HS0-26C32RH-QHS1-26C32RH-8HS1-26C32RH-QHS1-26C32RH/PROTOHS9-26C32RH-8HS9-26C32RH-QHS9-26C32RH/PROTOHS9G-26C32RH-QHS9G-26C32RH/PROTO
N123456789
Intersil D16.3Intersil D16.3Intersil D16.3
Корпус16 Ld SBDIP
Габаритный чертеж корпуса
16 Ld SBDIP
16 Ld SBDIP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
16 Ld CFP
Индекс корпусаD16.3D16.3D16.3K16.AK16.AK16.AK16.AK16.A
Количество выводов1616161616161616
СемействоSBDIPSBDIPSBDIPCFPCFPCFPCFPCFP
Parameters / ModelsHS0-26C32RH-QHS1-26C32RH-8
HS1-26C32RH-8
HS1-26C32RH-Q
HS1-26C32RH-Q
HS1-26C32RH/PROTO
HS1-26C32RH/PROTO
ClassV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTO
DLA SMD5962-956895962-956895962-956895962-956895962-956895962-956895962-956895962-956895962-95689
DescriptionRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line ReceiverRadiation Hardened Quad Differential Line Receiver
High Dose Rate (HDR) krad(Si)300300300300300300300300300
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelQML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)
SEL (MeV/mg/cm2)100100100100100100100100100
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
HS-26C32EH HS-26C32RH-T
  • Space & Harsh Environment > Rad Hard Analog > RH Interface
На английском языке: Datasheet Intersil HS-26C32RH
