Datasheet MC33340DG - ON Semiconductor Даташит ИС, зарядное устройство батареи аккумуляторов NICD NIMH 50 мА SOIC8 — Даташит
ON Semiconductor MC33340DG
Наименование модели: MC33340DG
10 предложений от 9 поставщиков
Romstore
Россия, Беларусь
MC33340DG
от 287 ₽
MC33340DG
MC33340DG
SUV System
MC33340DG
АЦП азиатских производителей
Производитель: ON Semiconductor
Описание: ИС, зарядное устройство батареи аккумуляторов NICD NIMH 50 мА SOIC8
data sheetСкачать Data Sheet
MC33340, MC33342 Battery Fast Charge Controllers
The MC33340 and MC33342 are monolithic control IC's that are specifically designed as fast charge controllers for Nickel Cadmium (NiCd) and Nickel Metal Hydride (NiMH) batteries.
These devices feature negative slope voltage detection as the primary means for fast charge termination. Accurate detection is ensured by an output that momentarily interrupts the charge current for precise voltage sampling. An additional secondary backup termination method can be selected that consists of either a programmable time or temperature limit. Protective features include battery over and undervoltage detection, latched over temperature detection, and power supply input undervoltage lockout with hysteresis. Fast charge holdoff time is the only difference between the MC33340 and the MC33342. The MC33340 has a typical holdoff time of 177 seconds and the MC33342 has a typical holdoff time of 708 seconds. · Negative Slope Voltage Detection with 4.0 mV Sens
  • Battery Type: NiCd / NiMH
  • Входное напряжение: 18 В
  • Battery Charge Voltage: 20 В
  • Battery IC Case Style: SOIC
  • Количество выводов: 8
  • Рабочий диапазон температрур: -25°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 33340
  • Battery Management Function: Charge Controller
  • IC Generic Number: 33340
  • Входное напряжение максимальное: 18 В
  • Количество логических функций: 33340
  • Способ монтажа: SMD
  • Power Supply IC Type: Battery charger
  • Диапазон напряжения питания: 3.25 В ... 18 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 5 SA
  • Fischer Elektronik - WLK 5
  • Roth Elektronik - RE932-01
На английском языке: Datasheet MC33340DG - ON Semiconductor IC, BATTERY CHARGER NICD NIMH 50 mA SOIC8
