Линейка продуктов KEEN SIDE
Datasheet Intersil IS-1845ASRH — Даташит
ПроизводительIntersil
СерияIS-1845ASRH
Высокоскоростной ШИМ в режиме тока
IS-1845ASRH, IS-1845ASEH Datasheet
PDF, 168 Кб, Версия: 2017-11-22
Single Event Radiation Hardened High Speed, Current Mode PWM
IS-1845ASRH_08
Intersil
IS0-1845ASRH-QIS7-1845ASRH-8IS7-1845ASRH-QIS7-1845ASRH/PROTOIS9-1845ASRH-8IS9-1845ASRH-QIS9-1845ASRH/PROTO
N1234567
Intersil D8.3Intersil D8.3Intersil D8.3
Корпус8 Ld SBDIP
Габаритный чертеж корпуса
8 Ld SBDIP
8 Ld SBDIP
18 Ld CFP
18 Ld CFP
18 Ld CFP
Индекс корпусаD8.3D8.3D8.3K18.BK18.BK18.B
Количество выводов888181818
СемействоSBDIPSBDIPSBDIPCFPCFPCFP
Parameters / ModelsIS0-1845ASRH-QIS7-1845ASRH-8
IS7-1845ASRH-8
IS7-1845ASRH-Q
IS7-1845ASRH-Q
IS7-1845ASRH/PROTO
IS7-1845ASRH/PROTO
ClassV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTOV, Q, /PROTO
DLA SMD5962-015095962-015095962-015095962-015095962-015095962-015095962-01509
DescriptionHigh Speed, Current Mode PWMHigh Speed, Current Mode PWMHigh Speed, Current Mode PWMHigh Speed, Current Mode PWMHigh Speed, Current Mode PWMHigh Speed, Current Mode PWMHigh Speed, Current Mode PWM
High Dose Rate (HDR) krad(Si)300300300300300300300
Low Dose Rate (ELDRS) krad(Si)In QualificationIn QualificationIn QualificationIn QualificationIn QualificationIn QualificationIn Qualification
Рабочий диапазон температурот -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Qualification LevelQML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)QML Class Q (military), QML Class V (space)
SEL (MeV/mg/cm2)SEL freeSEL freeSEL freeSEL freeSEL freeSEL freeSEL free
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
IS-1845ASEH
  • Space & Harsh Environment > Rad Hard Power > RH Switching Controllers
На английском языке: Datasheet Intersil IS-1845ASRH
