Datasheet Songle Relay SRU (22F) — Даташит
ПроизводительSongle Relay
СерияSRU (22F)
Реле для бытовых электроприборов
Datasheet SRU
PDF, 3.9 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
SRU-05VDC-FD-ASRU-05VDC-FD-BSRU-05VDC-FD-CSRU-05VDC-FL-ASRU-05VDC-FL-BSRU-05VDC-FL-CSRU-05VDC-SD-ASRU-05VDC-SD-BSRU-05VDC-SD-CSRU-05VDC-SL-ASRU-05VDC-SL-BSRU-05VDC-SL-CSRU-06VDC-FD-ASRU-06VDC-FD-BSRU-06VDC-FD-CSRU-06VDC-FL-ASRU-06VDC-FL-BSRU-06VDC-FL-CSRU-06VDC-SD-ASRU-06VDC-SD-BSRU-06VDC-SD-CSRU-06VDC-SL-ASRU-06VDC-SL-BSRU-06VDC-SL-CSRU-09VDC-FD-ASRU-09VDC-FD-BSRU-09VDC-FD-CSRU-09VDC-FL-ASRU-09VDC-FL-BSRU-09VDC-FL-CSRU-09VDC-SD-ASRU-09VDC-SD-BSRU-09VDC-SD-CSRU-09VDC-SL-ASRU-09VDC-SL-BSRU-09VDC-SL-CSRU-12VDC-FD-ASRU-12VDC-FD-BSRU-12VDC-FD-CSRU-12VDC-FL-ASRU-12VDC-FL-BSRU-12VDC-FL-CSRU-12VDC-SD-ASRU-12VDC-SD-BSRU-12VDC-SD-CSRU-12VDC-SL-ASRU-12VDC-SL-BSRU-12VDC-SL-CSRU-18VDC-FD-ASRU-18VDC-FD-BSRU-18VDC-FD-CSRU-18VDC-FL-ASRU-18VDC-FL-BSRU-18VDC-FL-CSRU-18VDC-SD-ASRU-18VDC-SD-BSRU-18VDC-SD-CSRU-18VDC-SL-ASRU-18VDC-SL-BSRU-18VDC-SL-CSRU-24VDC-FD-ASRU-24VDC-FD-BSRU-24VDC-FD-CSRU-24VDC-FL-ASRU-24VDC-FL-BSRU-24VDC-FL-CSRU-24VDC-SD-ASRU-24VDC-SD-BSRU-24VDC-SD-CSRU-24VDC-SL-ASRU-24VDC-SL-BSRU-24VDC-SL-CSRU-36VDC-FD-ASRU-36VDC-FD-BSRU-36VDC-FD-CSRU-36VDC-FL-ASRU-36VDC-FL-BSRU-36VDC-FL-CSRU-36VDC-SD-ASRU-36VDC-SD-BSRU-36VDC-SD-CSRU-36VDC-SL-ASRU-36VDC-SL-BSRU-36VDC-SL-CSRU-48VDC-FD-ASRU-48VDC-FD-BSRU-48VDC-FD-CSRU-48VDC-FL-ASRU-48VDC-FL-BSRU-48VDC-FL-CSRU-48VDC-SD-ASRU-48VDC-SD-BSRU-48VDC-SD-CSRU-48VDC-SL-ASRU-48VDC-SL-BSRU-48VDC-SL-C
N123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596
Размеры, мм29.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.029.0×24.5×15.0 | 32.0×27.4×20.0
Parameters / ModelsSRU-05VDC-FD-A
SRU-05VDC-FD-A
SRU-05VDC-FD-B
SRU-05VDC-FD-B
SRU-05VDC-FD-C
SRU-05VDC-FD-C
SRU-05VDC-FL-A
SRU-05VDC-FL-A
SRU-05VDC-FL-B
SRU-05VDC-FL-B
SRU-05VDC-FL-C
SRU-05VDC-FL-C
SRU-05VDC-SD-A
SRU-05VDC-SD-A
SRU-05VDC-SD-B
SRU-05VDC-SD-B
SRU-05VDC-SD-C
SRU-05VDC-SD-C
SRU-05VDC-SL-A
SRU-05VDC-SL-A
SRU-05VDC-SL-B
SRU-05VDC-SL-B
SRU-05VDC-SL-C
SRU-05VDC-SL-C
SRU-06VDC-FD-A
SRU-06VDC-FD-A
SRU-06VDC-FD-B
SRU-06VDC-FD-B
SRU-06VDC-FD-C
SRU-06VDC-FD-C
SRU-06VDC-FL-A
SRU-06VDC-FL-A
SRU-06VDC-FL-B
SRU-06VDC-FL-B
SRU-06VDC-FL-C
SRU-06VDC-FL-C
SRU-06VDC-SD-A
SRU-06VDC-SD-A
SRU-06VDC-SD-B
SRU-06VDC-SD-B
SRU-06VDC-SD-C
SRU-06VDC-SD-C
SRU-06VDC-SL-A
SRU-06VDC-SL-A
SRU-06VDC-SL-B
SRU-06VDC-SL-B
SRU-06VDC-SL-C
SRU-06VDC-SL-C
SRU-09VDC-FD-A
SRU-09VDC-FD-A
SRU-09VDC-FD-B
SRU-09VDC-FD-B
SRU-09VDC-FD-C
SRU-09VDC-FD-C
SRU-09VDC-FL-A
SRU-09VDC-FL-A
SRU-09VDC-FL-B
SRU-09VDC-FL-B
SRU-09VDC-FL-C
SRU-09VDC-FL-C
SRU-09VDC-SD-A
SRU-09VDC-SD-A
SRU-09VDC-SD-B
SRU-09VDC-SD-B
SRU-09VDC-SD-C
SRU-09VDC-SD-C
SRU-09VDC-SL-A
SRU-09VDC-SL-A
SRU-09VDC-SL-B
SRU-09VDC-SL-B
SRU-09VDC-SL-C
SRU-09VDC-SL-C
SRU-12VDC-FD-A
SRU-12VDC-FD-A
SRU-12VDC-FD-B
SRU-12VDC-FD-B
SRU-12VDC-FD-C
SRU-12VDC-FD-C
SRU-12VDC-FL-A
SRU-12VDC-FL-A
SRU-12VDC-FL-B
SRU-12VDC-FL-B
SRU-12VDC-FL-C
SRU-12VDC-FL-C
SRU-12VDC-SD-A
SRU-12VDC-SD-A
SRU-12VDC-SD-B
SRU-12VDC-SD-B
SRU-12VDC-SD-C
SRU-12VDC-SD-C
SRU-12VDC-SL-A
SRU-12VDC-SL-A
SRU-12VDC-SL-B
SRU-12VDC-SL-B
SRU-12VDC-SL-C
SRU-12VDC-SL-C
SRU-18VDC-FD-A
SRU-18VDC-FD-A
SRU-18VDC-FD-B
SRU-18VDC-FD-B
SRU-18VDC-FD-C
SRU-18VDC-FD-C
SRU-18VDC-FL-A
SRU-18VDC-FL-A
SRU-18VDC-FL-B
SRU-18VDC-FL-B
SRU-18VDC-FL-C
SRU-18VDC-FL-C
SRU-18VDC-SD-A
SRU-18VDC-SD-A
SRU-18VDC-SD-B
SRU-18VDC-SD-B
SRU-18VDC-SD-C
SRU-18VDC-SD-C
SRU-18VDC-SL-A
SRU-18VDC-SL-A
SRU-18VDC-SL-B
SRU-18VDC-SL-B
SRU-18VDC-SL-C
SRU-18VDC-SL-C
SRU-24VDC-FD-A
SRU-24VDC-FD-A
SRU-24VDC-FD-B
SRU-24VDC-FD-B
SRU-24VDC-FD-C
SRU-24VDC-FD-C
SRU-24VDC-FL-A
SRU-24VDC-FL-A
SRU-24VDC-FL-B
SRU-24VDC-FL-B
SRU-24VDC-FL-C
SRU-24VDC-FL-C
SRU-24VDC-SD-A
SRU-24VDC-SD-A
SRU-24VDC-SD-B
SRU-24VDC-SD-B
SRU-24VDC-SD-C
SRU-24VDC-SD-C
SRU-24VDC-SL-A
SRU-24VDC-SL-A
SRU-24VDC-SL-B
SRU-24VDC-SL-B
SRU-24VDC-SL-C
SRU-24VDC-SL-C
SRU-36VDC-FD-A
SRU-36VDC-FD-A
SRU-36VDC-FD-B
SRU-36VDC-FD-B
SRU-36VDC-FD-C
SRU-36VDC-FD-C
SRU-36VDC-FL-A
SRU-36VDC-FL-A
SRU-36VDC-FL-B
SRU-36VDC-FL-B
SRU-36VDC-FL-C
SRU-36VDC-FL-C
SRU-36VDC-SD-A
SRU-36VDC-SD-A
SRU-36VDC-SD-B
SRU-36VDC-SD-B
SRU-36VDC-SD-C
SRU-36VDC-SD-C
SRU-36VDC-SL-A
SRU-36VDC-SL-A
SRU-36VDC-SL-B
SRU-36VDC-SL-B
SRU-36VDC-SL-C
SRU-36VDC-SL-C
SRU-48VDC-FD-A
SRU-48VDC-FD-A
SRU-48VDC-FD-B
SRU-48VDC-FD-B
SRU-48VDC-FD-C
SRU-48VDC-FD-C
SRU-48VDC-FL-A
SRU-48VDC-FL-A
SRU-48VDC-FL-B
SRU-48VDC-FL-B
SRU-48VDC-FL-C
SRU-48VDC-FL-C
SRU-48VDC-SD-A
SRU-48VDC-SD-A
SRU-48VDC-SD-B
SRU-48VDC-SD-B
SRU-48VDC-SD-C
SRU-48VDC-SD-C
SRU-48VDC-SL-A
SRU-48VDC-SL-A
SRU-48VDC-SL-B
SRU-48VDC-SL-B
SRU-48VDC-SL-C
SRU-48VDC-SL-C
Номинальное рабочее напряжение, В555555555555666666666666999999999999121212121212121212121212181818181818181818181818242424242424242424242424363636363636363636363636484848484848484848484848
  • Household appliance relay
На английском языке: Datasheet Songle Relay SRU (22F)
