Datasheet Songle Relay SRU-24VDC-SD-A — Даташит
| Производитель | Songle Relay |
| Серия | SRU (22F) |
| Модель | SRU-24VDC-SD-A |
Реле для бытовых электроприборов
Datasheet SRU
PDF, 3.9 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
5 предложений от 5 поставщиков HF21FF/024-1HS (SRU(22F)-24VDC-SL-C) 15А-конт.1С реле Songle | |||
| SRU-24VDC-SL-C | 33 ₽ | ||
| SRU-24VDC-SL-C Songle Relay | 33 ₽ | ||
| SRU-24VDC-SL-C Songle Relay | по запросу | ||
| SRU-24VDC-SL-C | по запросу | ||
| Размеры | 29.0×24.5×15.0 | 32.0×27.4×20.0 мм |
| Номинальное рабочее напряжение | 24 В |
Серия: SRU (22F) (96)
- SRU-05VDC-FD-A SRU-05VDC-FD-B SRU-05VDC-FD-C SRU-05VDC-FL-A SRU-05VDC-FL-B SRU-05VDC-FL-C SRU-05VDC-SD-A SRU-05VDC-SD-B SRU-05VDC-SD-C SRU-05VDC-SL-A SRU-05VDC-SL-B SRU-05VDC-SL-C SRU-06VDC-FD-A SRU-06VDC-FD-B SRU-06VDC-FD-C SRU-06VDC-FL-A SRU-06VDC-FL-B SRU-06VDC-FL-C SRU-06VDC-SD-A SRU-06VDC-SD-B SRU-06VDC-SD-C SRU-06VDC-SL-A SRU-06VDC-SL-B SRU-06VDC-SL-C SRU-09VDC-FD-A SRU-09VDC-FD-B SRU-09VDC-FD-C SRU-09VDC-FL-A SRU-09VDC-FL-B SRU-09VDC-FL-C SRU-09VDC-SD-A SRU-09VDC-SD-B SRU-09VDC-SD-C SRU-09VDC-SL-A SRU-09VDC-SL-B SRU-09VDC-SL-C SRU-12VDC-FD-A SRU-12VDC-FD-B SRU-12VDC-FD-C SRU-12VDC-FL-A SRU-12VDC-FL-B SRU-12VDC-FL-C SRU-12VDC-SD-A SRU-12VDC-SD-B SRU-12VDC-SD-C SRU-12VDC-SL-A SRU-12VDC-SL-B SRU-12VDC-SL-C SRU-18VDC-FD-A SRU-18VDC-FD-B SRU-18VDC-FD-C SRU-18VDC-FL-A SRU-18VDC-FL-B SRU-18VDC-FL-C SRU-18VDC-SD-A SRU-18VDC-SD-B SRU-18VDC-SD-C SRU-18VDC-SL-A SRU-18VDC-SL-B SRU-18VDC-SL-C SRU-24VDC-FD-A SRU-24VDC-FD-B SRU-24VDC-FD-C SRU-24VDC-FL-A SRU-24VDC-FL-B SRU-24VDC-FL-C SRU-24VDC-SD-A SRU-24VDC-SD-B SRU-24VDC-SD-C SRU-24VDC-SL-A SRU-24VDC-SL-B SRU-24VDC-SL-C SRU-36VDC-FD-A SRU-36VDC-FD-B SRU-36VDC-FD-C SRU-36VDC-FL-A SRU-36VDC-FL-B SRU-36VDC-FL-C SRU-36VDC-SD-A SRU-36VDC-SD-B SRU-36VDC-SD-C SRU-36VDC-SL-A SRU-36VDC-SL-B SRU-36VDC-SL-C SRU-48VDC-FD-A SRU-48VDC-FD-B SRU-48VDC-FD-C SRU-48VDC-FL-A SRU-48VDC-FL-B SRU-48VDC-FL-C SRU-48VDC-SD-A SRU-48VDC-SD-B SRU-48VDC-SD-C SRU-48VDC-SL-A SRU-48VDC-SL-B SRU-48VDC-SL-C
- Household appliance relay
SRU24VDCSDA, SRU 24VDC SD A
